AC center Vent Issues
Old Mar 13, 2019 | 08:31 AM
Wayne Lea's Avatar
Default AC center Vent Issues
Hello everybody:
I would just like to post this thread and get your feedback please.
I own a 1997 XJ6 VDP with 74,000 miles on her. And I am having an issue with my air conditioning. Everything was working fine and all of a sudden the two center vents stopped blowing. The two small side vents are blowing fine. There is a slight breeze of cold air coming out of the two center large vents, but it is not blowing hard like it was. I was wondering if somebody on this forum might have come across the same issue?
I truly appreciate everyone’s time and Input in this subject.
Regards,
Wayne.
Old Mar 13, 2019 | 09:13 AM
Wayne,
I've moved your question from General Tech Help to X300 forum. Members here with the same model will be able to help.
My first thought is the servo motor which moves the flaps in the AC unit to direct the airflow could have failed.
Old Mar 13, 2019 | 10:19 AM
Lady Penelope's Avatar
There is a self test on the AC control panel that may give you information
http://www.jagrepair.com/images/TSB/...stem%20DTC.pdf
The vent doors ( or trim doors ) have both a motor and a position sensor and the motors can be run with a 9 volt battery to the position you want assuming the motor is OK
You can actually hear them saving you from taking things apart
An overview of the X300 system is in the attached Doc on page 45 for the X300 and X308 , 78 for the center plenum containing the center vents in question and Z
There is a difference in the X300 and X308 in the center vent ( face vent ) on the X308 does not have the adjustment thumbwheel ( differential control potentiometer )
File Type: pdf
Old Mar 13, 2019 | 01:37 PM
Wayne Lea's Avatar
Core Blimey.
Thank You very much Sir.
Hoosier XK8
May 22, 2017 04:04 PM
J8levi
Feb 19, 2015 11:45 AM
jagnut1025
Sep 24, 2009 05:14 PM
photog77
Aug 27, 2009 10:10 PM
michaelnv
May 11, 2008 02:46 PM
