air conditioning question
Old Jul 15, 2009 | 09:02 PM
christian's Avatar
Default air conditioning question
1997 xj6 87000 miles, air went hot so i put a bottle of recharge/sealer in and as soon as i opened the can the compressor(i think) started to make a slight screeching noise, ac was cold for 10 minutes then hot again, bad compressor???/
thanks
Old Jul 16, 2009 | 12:00 AM
Thermo's Avatar
Veteran: Navy
Sounds like the seal on the compressor is toast. I would take the car to an A/C shop and have them do a vacuum drop test on the system. That will tell you if there is a leak in the system. They will then also be able to do a dye test and prove what the leaky component is.
I wish you luck.
Kevin Burnaby
Jun 28, 2020 08:04 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
jgatto
Sep 21, 2015 11:24 PM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
Whitnessmouse
Sep 4, 2015 11:09 AM
