Air Control Valve
Old Dec 29, 2022 | 09:27 AM
Marty Malone's Avatar
Default Air Control Valve
I have a 95 Vanden Plas. I watched a video that suggested the cleaning of the throttle body and replacing the air control valve. Is it a good idea to replace this valve, and if so, where is the best place to get one? I think this was suggested as a preventative measure. Thanks!
Old Dec 29, 2022 | 11:39 AM
Parker 7's Avatar
Someone recently had a substation part for the inlet air control valve
Do not remove the throttle position sensor as this is a important adjustment you don't want to lose
The bolts tend to break off on removal of the IAC valve so heat from the inside of the throttle body is recommended
the bolts are a odd 5.5 mm or 6.5 mm and about the only time to get it off with tight bolt head side clearances
There is no gasket on the throttle body to intake manifold but there is one on the IAC valve
OESIII
Jul 24, 2021 02:20 AM
stuart goodwin
Oct 7, 2018 09:13 AM
Paulie63
Sep 14, 2016 10:03 AM
RJ237
Jan 24, 2013 08:06 PM
STR
Aug 9, 2010 07:06 AM
