Is the AJ16 Engine a Interference Engine ?
Old Jul 7, 2020 | 09:39 PM
Parker 2's Avatar
Default Is the AJ16 Engine a Interference Engine ?
Interference in terms of valves hitting the pistons if the timing chain is off adjustment
Asking for a friend
Old Jul 8, 2020 | 07:32 AM
countyjag's Avatar
I have inadvertently run my XJR with the timing a tooth out, and whilst it wasnt ideal, no damage ensued. That said, I believe that it is an interference engine, and that if the valvetrain becomes static, it will be hit by the pistons.
Old Jul 8, 2020 | 09:35 AM
Parker 2's Avatar
Although my engine is fine I was always curious if it was more then 2 teeth off or maybe 15 degrees one direction or the other
This is for VVT considerations where the chain is installed in it's proper factory position for a VVT at rotary actuator neutral
Old Jul 8, 2020 | 10:59 AM
motorcarman's Avatar
The AJ6/AJ16 engines do not have VVT.
The AJV8 Jaguar engines with VVT vary only the INTAKE cam.
Old Jul 8, 2020 | 06:36 PM
Vee's Avatar
Vee
https://www.jaguarforums.com/forum/x...e-head-149032/
https://www.jaguarforums.com/forum/x...valves-211876/
Cyber160
XJ XJ12 ( X305 )
Oct 5, 2020 11:03 PM
JensenHealey
Dec 23, 2018 04:16 AM
Eddie602
May 20, 2017 11:22 AM
Rogelio Serrano
Apr 27, 2017 05:16 PM
Lavaman
Feb 15, 2015 09:03 AM
