Alarm horn/lights after extended battery disconnect on 97 USA VDP
Old Apr 23, 2015 | 11:04 PM
gbmtkj's Avatar
Smile Alarm horn/lights after extended battery disconnect on 97 USA VDP
I had the battery disconnected for a number of weeks, related to a battery rundown issue (may need a separate post on that later), and not having time to get back to the job.
Now, when I reconnect 12V at the battery, I get flashing lights and horn (I've now removed the horn fuses to avoid disturbing the neighborhood). It stops after a minute or so. Also stops with turning key in ignition. But after removing key or opening door, it starts again.
How do I get the security system back to normal operation?
FYI, I only have keys, no fob.
Old Apr 26, 2015 | 05:17 PM
gbmtkj's Avatar
Solved! For now...
Connecting a new battery in place of the old (not just parallel) allowed re-connection without the alarming lights and horn!
Now I can get back to my no-crank issue, but I know there's plenty of help to check out first at Gentlemen (No) Start Your Engines.
Forcedair1
Sep 8, 2025 01:57 PM
aholbro1
Dec 29, 2024 06:46 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
DuhCar
Sep 11, 2015 10:58 AM
