Amp installation
Old Apr 28, 2016 | 01:21 PM
jomo's Avatar
Default Amp installation
Hi,
I was wondering where I can find or make a hole to run speaker wires and RCA cables from the interior of the car to the boot/trunk on my 1996 XJS
Also how do i go about changing my signature to add my newly acquired car?
Thanks!
Old Apr 28, 2016 | 02:22 PM
Harry Dredge's Avatar
Hi, you might be able to push them through the tunnel down the middle of the car (I forget the actual name) I had a look at doing that but it looked like a pain :P
I ended up taking signal from the rear tweeters, accessible through the boot.
There's even a cable you can use for the remote wire in the boot.
I assume you had a look at my guide I wrote up the other day, if not here's the link.
https://www.jaguarforums.com/forum/xj-xj6-xjr6-x300-26/guide-subwoofer-install-non-premium-factory-headunit-161704/
Old Apr 28, 2016 | 10:00 PM
aholbro1's Avatar
Might have better info on the XJS forum. There's a rubber grommet under the left side of the rear parcel shelf on the X300. Don't know if it exists on the XJS or not, though.
Old Apr 29, 2016 | 03:12 PM
jomo's Avatar
I was able to drill a hole to the trunk after removing the back seat.
Thanks for your responses.
themajor7
Apr 16, 2016 06:06 PM
Wcsteam
Apr 12, 2016 04:29 PM
ralphwg
Apr 11, 2016 06:59 PM
vinny jones
Apr 5, 2016 01:57 AM
bcucharternet
Apr 1, 2016 07:49 AM
