Another octopus question
Old Jan 19, 2013 | 11:56 PM
mgb4tim's Avatar
I went with scraping and emery cloth. Buttoned her up this afternoon, and took her out for a while tonight. I missed that car. I have't driven it since late October. It's good to have it back.
Old Jan 23, 2013 | 08:25 AM
mgb4tim's Avatar
I drove it all weekend, to work and to the church yesterday. When I got home, I figured it was a good idea to check. The coolant level was just at the "min" mark, and there's still a small leak (steam) coming from under the intake manifold. It's crowded enough under there that you just can't see where it's coming from.
I looked at all the octopus ends, and they are dry. I can't see the middle end of the bypass hose (the one from the back of the pump to the block-is that the right name?), but that has a new clamp and the surface was clean. If it's that, I can't even see the end of the clamp to snug it up
Any other suggestions?
Old Jan 23, 2013 | 10:10 AM
RJ237's Avatar
Yes, that's the bypass. If you take the cover off the fuel rail you will just be able to see the clamp. Access is certainly limited. I replaced mine when I had the air pump, water pump and octopus off, and it was not too bad. I had to use emory to remove the corrosion and deposits off the nipple.
Old Jan 24, 2013 | 08:14 AM
mgb4tim's Avatar
oh, I scraped, and scraped to get all the corrosion off. I'm going to see if I can find a borescope to borrow. I should be able to tuck it in there to see where it's coming from.
James007
Oct 3, 2015 03:29 PM
redgear
Sep 18, 2015 10:05 AM
SeanU
Sep 18, 2015 08:09 AM
kamiar
Sep 17, 2015 06:30 PM
DustysSon
Sep 13, 2015 04:17 AM
