Another timing tensioner question
Old Jul 19, 2023 | 09:31 PM
italcarnut's Avatar
Default Another timing tensioner question
As I am about to install a revised tensioner I ran across this TSB. http://www.jagrepair.com/images/TSB/...er%20Start.pdf. I was looking at an exploded view if the old one that called for two o rings, number 7 in the illustration. The old one and the used upgraded one don't have these. Are they necessary
Old Jul 20, 2023 | 01:22 AM
I dont recall #7 in any of the :revised units I have sorted. Very different innards to the original units.
#8 & 9 you will need, unless your old are still usable.
Old Jul 20, 2023 | 02:39 AM
Parker 7's Avatar
The revised tensioner takes a longer shank installation bolt ( s )
To short and you risk stripping the threads
On mine the previous owner had a leak past the hardened large O - ring
So they really cranked down on the 2 bolts in the original pre revised part to no sense
Old Jul 20, 2023 | 09:26 AM
italcarnut's Avatar
Thanks, gentlemen. I will be replacing the O ring EAC 4540 and gasket EAC 4557 and I wondered if those o rings were necessary. Lots of work sorting out an old car, but very satisfying.
Old Jul 20, 2023 | 10:02 AM
motorcarman's Avatar
The old style original has an insert and shaft going THROUGH the tensioner body. It NEEDS the small 'O'ring to seal.
The updated one is CLOSED at the end and does not require the small 'O'ring. (no hole in the eng of the body)
Old Jul 21, 2023 | 09:26 AM
italcarnut's Avatar
I see!
No Quarter
Jun 6, 2022 07:30 AM
bjzwissler
Apr 2, 2021 06:39 AM
mitsurugi
Dec 17, 2014 03:04 AM
fR144
Feb 21, 2014 09:49 AM
linconlsv8
28
Feb 20, 2012 12:37 PM
