Antenna alternatives ?
Old Nov 1, 2014 | 05:31 PM
weisberg's Avatar
Default Antenna alternatives ?
I dislike the telescoping antenna purely for aesthetic reasons. Anyone tried replacing it by using a marine antenna run around the trunk OR disabling the motor to the antenna so if you just play CDs it doesn't come up? On my 2002 XKR coupe I simply had the power cord to the antenna disconnected for that same reason although in that case it was more visually at odds with the coupe's elegant curves.
Old Nov 1, 2014 | 11:23 PM
al_roethlisberger's Avatar
I haven't looked at the trigger for the Jaguar, but most power antennas use a simple on/off 12V trigger wire to trip a relay to raise and lower the antenna. You could easily cut into the trigger wire and install a switch somewhere.
My dad used to do this on our old full sized GM cars so he could control when the antenna went up/down. They were prone to wearing out by breaking the nylon 'cable' inside (aren't they all?!) so he would leave it up most of the time.
Old Nov 3, 2014 | 07:46 AM
mgb4tim's Avatar
I've often thought when I had the time to put a switch inline o the antenna to leave the basted thing down. I never use the radio, but usually Bluetooth from my phone (yes, I put in a new head unit)
Old Nov 4, 2014 | 03:44 PM
SleekJag12's Avatar
Funny how I replaced the antenna mast a while ago so it would work properly, only to be annoyed with it later. I like the idea of a switch in the trigger line. Still haven't done it. Pulling the power to the antenna is a safe option too.
oldjaglover
Dec 25, 2024 04:33 PM
philwarner
Jan 31, 2016 09:36 AM
10 XF Premium
Oct 2, 2015 09:22 PM
waynepaulj
Oct 2, 2015 04:05 PM
