Antenna mast problems
Old Aug 20, 2009 | 12:53 PM
JagtechOhio's Avatar
Nope, it isn't as easy as it sounds and this problem is pretty common. You're alot better off removing the assembly from the car, soaking the base of the mast with penetrant, grabbing the mast in a vise and yanking the motor off the mast. A few taps on the housing with a rubber mallet might be necessary.
You did unscrew the chrome mast retaining nut, right? There is no need to remove the rubber body grommet unless you are fitting a new one.
Old Aug 21, 2009 | 12:00 AM
poboyblues's Avatar
And if all the plastic gear train doesn't come out, you can take that bad boy apart and git it all out. Then reassemble. It's easy. Many a time people come in and buy a new motor assy, and don't need it. Good luck.
Old Oct 17, 2009 | 12:55 PM
blipner's Avatar
Default I can get it up just fine.. its getting it down...
Just recently, the antenna retracts leaving about 4 inches still up (no ribbing please!)... I can't even "force" it all the way down. Any ideas about what the cause is?
Old Nov 7, 2009 | 07:01 PM
italcarnut's Avatar
Smile antenna mast
I'm new at this, but did you turn the ignition key on, turn on the radio and yank the sucker out? Slip the new one in and shut the radio off. It seems it should work although very little seems easy on this car. What is a good source for an antenna mast?
Thanks,
Ruben Velez
99xk8guy
May 28, 2024 09:36 PM
mbergen
Oct 23, 2019 10:26 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
jehart49
Sep 12, 2015 05:36 PM
