Bad squealing sound
Old Sep 9, 2025 | 04:27 PM
jomo's Avatar
Default Bad squealing sound
Hi,
I have a bad squealing on my 95 xjs (6 cylinder)
Every time the alternator gauge reads low I hear squealing which sounds like a belt squealing to me.
Every time I start up the car it squeals for a few minutes. Once in a while it will squeal at other times. However, every time it squeals the alternator gauge reads low which usually happens after I start off from a traffic light or stop sign. Also, every tine the alternator reads low I hear the squealing noise. The belt itself looks fine.
I just look at the rotation of the belt and it looks like the belt is aligned up with all the pullys. Any ideas what I should be looking at?
Thanks,
Jomo
Old Sep 9, 2025 | 05:18 PM
944play's Avatar
If the belt isn't slipping, the harmonic balancer may be.
Old Sep 9, 2025 | 07:19 PM
motorcarman's Avatar
I used to use Dale Manufacturing and Damper Doctor but that was years ago.
Old Sep 11, 2025 | 07:01 PM
jomo's Avatar
Update: I tightened the alternator belt and the problem is gone!
Thanks for your inputs!
Old Sep 13, 2025 | 10:42 AM
Parker 7's Avatar
The alternator belt has little tension adjustment in reality , the belt size as official is critical
For a easy harmonic balancer check that Al has made a pic worth a thousand words
No belt removal required
On engine stop the white lines you have applied should line back together
Pic coming
On_a_Jag
Jun 5, 2025 05:32 PM
jmstunts
Jan 11, 2025 05:38 AM
gijoe50000
Oct 29, 2024 10:40 AM
dsetter
May 27, 2015 02:51 AM
97XJR-Flausa
Sep 4, 2014 08:47 PM
