Bad steering rack?
Old Dec 11, 2008 | 06:35 PM
toutlnone's Avatar
Default Bad steering rack?
Well I just bought a 96 xj6 ice blue with oatmeal interior 55000 original miles for 7000.Car is in excellent shape overall but I noticed that fluid was leaking from boots on both outer ends. of tie rods .Do I need new boots or is the steering rack bad, and how difficult is this to fix?[sm=dontgetit.gif]
Old Dec 11, 2008 | 06:54 PM
Brutal's Avatar
Default RE: Bad steering rack?
you can try Lucas power steering stop leak for $10, b ut if not yes you need a rebuilt rack
Old Dec 11, 2008 | 07:23 PM
toutlnone's Avatar
Is the boot a dust boot or is it designed to hold fluid?
Old Dec 11, 2008 | 09:53 PM
Dennis's Avatar
ud
You think you got problems with your steering RACK.....
Old Dec 11, 2008 | 10:06 PM
toutlnone's Avatar
Those were designed to hold fluidhow about my boots[sm=helpout.gif]
Old Dec 11, 2008 | 10:07 PM
Brutal's Avatar
no it should never have fluid in it
Old Dec 13, 2008 | 10:42 AM
toutlnone's Avatar
Thanks Brutal Im going to try lucas I appreciate the help. If I end up replacing the rack how big of a job is this?
Old Dec 13, 2008 | 11:54 AM
Brutal's Avatar
ITS NOT BAD, BUT YOULL NEED AN ALIGNMENT WHEN DONE, AND IF YOURE IN A NORTHERN CLIMATE YOU MAY NEED A TORCH! AND IF YOU GET A RACK LESS OUTER TIE RODS, REPLACE THOSE ALSO. MEASURE THE LENTH FROM TIE ROD TO TIE ROD AND SCREW THE NEWS ONES TOGETHER AS CLOSE TO THE SAME LENGTH AS POSSIBLE, THAT WAY YOU WONT SEVERLY TEAR UP YOUR TIRES GOING TO GET AN ALIGNMENT
Old Dec 13, 2008 | 01:02 PM
toutlnone's Avatar
tanks u da man! Whats the torch for?I live in troy il.
Old Dec 13, 2008 | 02:13 PM
Brutal's Avatar
FOR THE FACT THAT WHERE THE ROADS ARE SALTED, EVERYTHING UNDERNEATH RUSTS AND SEIZES
rusty37
Apr 5, 2020 07:40 PM
PMKimpton
Aug 3, 2019 08:22 PM
sogood
Sep 15, 2015 07:35 AM
Richard_gib
Sep 12, 2015 07:08 PM
Darrenmb
Sep 8, 2015 06:12 PM
