Belts
Old Nov 19, 2019 | 10:59 AM
Tom Murray's Avatar
Default Belts
Hi
I have a Daimler double six 6l v12.
This week I could hear a belt squeal noise which went away after revs.
I started her up this morning in the cold and a noise had started when I steer. After 5 seconds a smoke comes out.
Iv looked at the belts and the small thin belt which goes over the fan stops and starts. I don’t know where to start. Could this be a belt problem or is something stopping the belts rotation. The noise is pretty bad from the steering.
Thanks for looking.
Old Nov 19, 2019 | 07:24 PM
My 1st suggestion would be a new set of belts.
Age is probably an unknown, so a good place to start.
While the belts are off, hand rotate each pulley involved, "feeling" for any binding etc. Water pump, steer pump, idler pulleys etc etc.
Good luck.
Old Nov 19, 2019 | 07:26 PM
Tom Murray's Avatar
Good luck.
Thank you Grant
Old Nov 20, 2019 | 09:12 PM
SleekJag12's Avatar
Follow the Wise One's advice above. You may have a stuck pulley among the six.
You've named 3 issues... One from each of the 3 drive belts!
The squeal at startup could be the alternator belt slipping while the alternator works harder at start-up. Cold weather, a battery that's going off, and a loose belt can contribute.
The bonding on the alternator belt's run on the engine pulley could also be coming loose. This would cause a squeal or a screech after starting (delamination). This issue contributes to the battery going off.
The power steering pump is driven by the large belt that drives the a/c too. Loose belt or p/s fluid on the belt thats burning off? Smoke is never good.
The belt going over the fan pulley also drives the air pump, although you might not have an air pump, just an idler pulley. The idler could be stuck, that happens a lot with idlers. More important, this belt drives the water pump too. You want to keep that belt working at its best.
Cold weather = looser belts when cold. Situation made worse if they are older and not so supple anymore. Tension up the belts when cold so they are not loose.
Here is your required reading regarding the necessary belts:
XJ12 Drive Belts
Noticed this diagram is now missing from the original thread. Here it is again, large print version.
Last edited by SleekJag12; Nov 20, 2019 at 09:47 PM. Reason: Added missing diagram
Old Nov 21, 2019 | 01:41 AM
Tom Murray's Avatar
XJ12 Drive Belts
thank you that’s brilliant
Old Nov 21, 2019 | 08:25 PM
AL NZ's Avatar
sounds like a belt or harmonic balancer slipping, but check your power steering fluid too..
Old Dec 15, 2019 | 03:49 AM
Tom Murray's Avatar
Found the problem. Was the high pressure hose to the power steering. Had been leaking. New pipe and it’s ok.
only problem now is there’s no heating and the belts started to squeal when the heating is turned on.
looops
Jun 7, 2016 11:23 AM
dsetter
May 20, 2016 09:55 AM
Blue_XJ8
Mar 4, 2015 11:48 AM
Miami XKR
Mar 21, 2013 09:45 AM
Paul Mason
Feb 19, 2012 02:22 PM
