best OBDII scanner for x300
Old Dec 19, 2021 | 04:09 PM
jmstunts's Avatar
Default best OBDII scanner for x300
What is a good OBDII scanner for a x300? I have been looking at various different ones priced between $68 and $349.
Old Dec 19, 2021 | 08:37 PM
Vee's Avatar
Vee
What is it you want it to do? Just pull codes? The u480 is probably $15 or less.
Old Dec 20, 2021 | 07:59 AM
jmstunts's Avatar
Default scanner
I am looking for a scanner that will have the ability to clear codes on ABS and SRS, be able to read all functions etc. It also should work on my 2015 Mini and 2016 Mazda6.
Old Dec 20, 2021 | 09:56 AM
Vee's Avatar
Vee
That’s gonna cost you a lot more than $345 then. I don’t know about the Mini and the Mazda, but I’m order to access and clear ABS and Transmission codes on the Jaguar, it will need to be loaded with Jaguar specific software.
For the right amount, you can buy equipment that can also load BMW (for the Mini?) and Mazda protocols as well, but we’re probably talking about a four digit price.
Please keep us posted if you happen to find something that works!
Old Dec 20, 2021 | 11:50 AM
jmstunts's Avatar
Default icarsoft i930
Anyone here have any experience with this tool? ICARSOFT LR V1.0 LAND ROVER JAGUAR OBD2 CAR DIAGNOSTIC ENGINE CODE SCAN RPL i930
Old Dec 20, 2021 | 12:15 PM
Cafcpete's Avatar
Let me point you to this thread.
You can load bmw and Mazda on here as well but can not comment on these.
https://www.jaguarforums.com/forum/x...budget-249892/
Old Dec 20, 2021 | 02:25 PM
JezuzNoChill's Avatar
Can confirm that I bought an Autel AP200 to clear/read ABS codes and it works.
Old Dec 20, 2021 | 03:45 PM
Vee's Avatar
Vee
I forgot about this post. This should be a sticky at this point!
Old Dec 20, 2021 | 03:48 PM
jmstunts's Avatar
Thanks for the info.....Jack
Old Dec 27, 2021 | 12:29 PM
jmstunts's Avatar
Default scanner
Has anyone ever purchased or have any opinions on these 2 scanners?Foxwell NT604Elite, and icarsoft i930 I am trying to decide which is best for x300, 1996
Jack M
Old Dec 27, 2021 | 09:39 PM
Vee's Avatar
Vee
Jack M
Whats wrong with the Autel that has been confirmed to read transmission and ABS codes?
Old Dec 28, 2021 | 09:25 PM
Matto1965's Avatar
Hi I have the TRANS mil light flashing ((1995 X300 4.0L) - have changed the TRANS control module to the recommended one but still cannot clear the flashing light. I don't get any codes with the current OBDII I have - do you think that the AUTEL might help out here ?
Old Dec 29, 2021 | 12:49 PM
Vee's Avatar
Vee
Sounds like it will.
is your light flashing, or on steadily?
You shouldn’t need to clear the light, as the transmission will run a self test upon restart. But the OBD2 reader will pull the code, which should be invaluable to solving your problem.
Is the car driving normally?
Old Dec 29, 2021 | 05:36 PM
Matto1965's Avatar
Hi light is flashing all the time. Trans runs perfectly but I get no codes at all relating to the Trans. Clearing all codes on my current OBDii does not stop the flashing light. I have also put back the old TRANS ecu and nothing changes? Stumped?
Old Dec 30, 2021 | 02:41 AM
Cafcpete's Avatar
Do you KNOW that your ODB reader can READ TRANS codes?
Old Dec 30, 2021 | 09:53 AM
Vee's Avatar
Vee
You should order that OBD2 reader so you can pull the transmission code. Not sure anyone can help you without knowing what the code, or problem is.
I can guarantee that the OBD2 reader will pay for itself, since it will pull the Jaguar specific ABS and Transmission codes, as well as the common P codes.
Old Dec 30, 2021 | 05:27 PM
Matto1965's Avatar
I have the NextDig ND602 Land Rover / Jaguar ObdIi which stares it reads Trans codes
Old Dec 31, 2021 | 08:30 AM
Vee's Avatar
Vee
Do you get ANY codes?
Old Jan 1, 2022 | 03:13 PM
Matto1965's Avatar
I have run it several times and get no codes at all?
Old Jan 1, 2022 | 05:58 PM
Vee's Avatar
Vee
Something is clearly not right. You have a transmission light on (steady, not blinking) and an OBD2 reader that (allegedly) reads Jaguar specific transmission codes, but you come up empty?
How can we be sure that the reader does indeed read Jaguar specific transmission codes?
Have you ever been able to pull a transmission code previously? Any code? Is this the first time youre using this reader?
