Cable snapped
Old Sep 7, 2023 | 06:03 AM
ormy49's Avatar
Default Cable snapped
Hello fellow enthusiasts ,on my x300 there is a cable\ wire that connects the bonnet to frame of the car it has corroded and snapped . Does this wire affect the cars electrics as I have a few issues ,ie power seats mirrors and drivers widow not working .all fuses ok.
Old Sep 7, 2023 | 08:35 AM
katar83's Avatar
It doesn't, its there to mainly shield unwanted RF signals so reduces noise, its good idea to replace it, plenty available and they are cheap but its not critical.
Old Sep 7, 2023 | 02:03 PM
Parker 7's Avatar
The side mirrors are controlled by a module by the steering collum
The seats have there own control and the common factor between the seat and window is the driver door control
What I found with mine was the connector socket lock bar was loose allowing the sockets to move away from connection
Someone made a set of instructions on removing the door card / panel
When you locate the heavy gauge wires to the window motor you can drive it up and down with a battery charger to confirm you have a good motor / regulator , just swap polarity to go up and down
In the end you have to press the up button for a while at the full window closed position so it learns this position
Looking for your fuses
The # 1 fuse is closest to the large B + post on each fuse box
So you have 1 - 9 row closest to the B + post on the box and the next row comes back to start with # 10
Ask questions
Old Sep 7, 2023 | 02:09 PM
Parker 7's Avatar
See page 21 and on
X300 1996 LWB.pdf (jagrepair.com)
Andwell
Jun 26, 2021 05:35 AM
JayJagJay
Aug 8, 2019 10:14 AM
kennyjd
Mar 19, 2016 03:06 AM
98jags
Mar 6, 2013 12:02 PM
e21pilot
Jan 9, 2012 07:58 AM
