Center console and door lighting going out over bumps.
Old Jan 18, 2019 | 08:34 PM
Ric in RVA's Avatar
Default Center console and door lighting going out over bumps.
My door switch lighting on both front doors and my center console lighting go out and come back on simultaneously when I hit a bump. Any advice on where to start or a wiring diagram that I can locate a likely plug or ground that is going bad?
Old Jan 18, 2019 | 10:12 PM
Lady Penelope's Avatar
Before I forget a X300 came into a salvage yard Thursday that may have a original alternator for the taking , I didn't look at it as was looking at other things .
Now back to your lights
See page 92 or abouts
Is there a group of lighting in the print that matches your issue ?
I see a single bulb center consol switch pack and a driver and pass door switch pack , is that the area of interest ?
They have different grounds so that rules that path out
By putting the small dimmer knob on the steering column to override does that make a difference as you test drive it ?
http://www.jagrepair.com/images/Auto.../jagxj1997.pdf
Bed time now
Old Jan 19, 2019 | 12:03 PM
aholbro1's Avatar
You need to clean and tighten the grounding stud on the back of your head unit.
https://www.jaguarforums.com/forum/x...09/#post338514
Old Jan 21, 2019 | 09:26 AM
Ric in RVA's Avatar
Seems no change but that makes sense since my dah lights are unaffected and they are on the circuit. I have it fairly well isolated using those diagrams. Now I need to hunt for wires and plug. I'll probably start with center console and check grounds then branch out from there. Probably a loose plug somewhere.
Thanks for the help and ideas!!!
Andrew Steven
Dec 3, 2017 02:58 PM
AlexPeel
Feb 21, 2017 06:03 PM
BillDJohnson
Jun 19, 2013 09:04 PM
JaguarXKR
May 4, 2011 10:39 PM
p3x935
Aug 12, 2010 11:10 PM
