Central locking
Old Jun 3, 2022 | 09:06 AM
Js2022's Avatar
Default Central locking
Why do the doors lock like a London taxi when I drive off? I would like this feature switched off if possible. Is it actually a fault with the central locking? I worry the solenoids will wear being activated alot like this..
Old Jun 3, 2022 | 09:27 AM
motorcarman's Avatar
Jaguar refers to it as 'Drive Away Door Locking' and should be a configurable feature.
Old Jun 4, 2022 | 04:10 AM
OxfordJoe's Avatar
Default Sign of the times
It’s likely a setting option.
Thefts of belongings like laptops or handbags from stationary cars at traffic light or congestion stops are sadly not unknown even in supposedly civilised cities.
Old Jun 11, 2022 | 08:53 PM
Bill Mac's Avatar
I doubt if the locking solenoids will ever wear out.
Car hijacking does occur even in civilized countries and a locked door is reasonable barrier to anyone unless they have a firearm.
By the way the system uses a speed sensor to feed information to the door locking computer which is in the left hand side of the boot or trunk ( depending where you live)
I am not aware of any option to disable this function.
Old Jun 12, 2022 | 01:43 AM
John Herbert's Avatar
Bill, like most issues, there is a way, see my attachment. I also found this feature annoying.
In line with comment by Motorcarman, I believe this feature could be configured on or off via the dealers at the time, however very few may have the required equipment these days.
The wire to be disconnected could of course be reinstated at any time if required.
John Herbert
(1996 XJR)
File Type: pdf
Old Jun 12, 2022 | 11:05 PM
Bill Mac's Avatar
As you say there is a way but it would not be a simple case of a "setting." but actually requiring some surgery/modification on the wiring.
Modifications by previous owners can be a pain.
My current X300 which came from the deceased estate of an acquaintance had a mod. to the electric aerial function.
The aerial would not work and my acquaintance had two other aerials in the car boot all of which were serviceable. He had been trying!
I eventually hunted down the problem and found a discrete switch in the back of the centre console glove compartment which interrupted power from the radio.
Not in favour of cutting the wire.
Johnnyw
28
Dec 22, 2021 07:08 AM
Hktk
Oct 9, 2021 08:13 AM
MJG
Dec 8, 2012 04:07 PM
rids
Jul 22, 2012 03:04 PM
driver safz
Jun 6, 2011 02:16 PM
