central locking bouncing 3 times before locking!
Old Jan 30, 2016 | 10:46 AM
iconic's Avatar
Default central locking bouncing 3 times before locking!
Hmm, it didn't do this before clearing a code 1641....may not be related though!
Been messing with the Jaguar today and went to lock her and found the central locking now is boucing 3 times before locking.
1....WD-40 the door locks? I've blasted them anyway..the drivers doorlock is a little stiff on the key.
2....sign of a 'in car' battery getting tired? Just put the battery on charge its pulling quite a charge into it, I've seen this with Mercs before.
....any advise guys? I think I may recheck the alternator volts under load for a intermitant fault....I did notice the blower speeded up at idle then slowed once the revs were up, strange?
Just been going thru the history and this old bus has only just covered....5,000 k miles in the last 9 years!
....methinks she needs using a and few gremlins will pop out the over the next few weeks?
Old Jan 30, 2016 | 11:43 AM
aholbro1's Avatar
As expected -your blower is speed-sensitive. So unless you were just sitting still revving the engine (be careful here, as there is a TSB cautioning about transmission damage from operation above 2k rpm in park or neutral) then greater rpm would result in increasing speed, which will retard blower speed to compensate for increased ram-air pressure.
(also with increased speed, intermittent wiper speeds up, radio gets louder, and steering gets stiffer, btw)
Old Jan 30, 2016 | 11:49 AM
aholbro1's Avatar
I found a code 1621.....ran it around without clearing, then decided to clear that code after a drive and now I find the central locking is bouncing 3 times before locking....!!!
Haha...I realize how easy this can happen....but we're gonna need you to get your story straight!
Old Jan 30, 2016 | 12:23 PM
iconic's Avatar
Solved! Working ok now the battery is on charge, system must be very sensitive to low battery volts....only been moving her around parts few weeks, not been driven further than 10 miles, could be the cause?
Old Jan 30, 2016 | 01:52 PM
sparkenzap's Avatar
In a word, YES! These cars are extremely sensitive to battery voltage, and it might not be just voltage. As a battery gets some age, its impedence rises, allowing the alternator to cause ripple on the power bus. Several of us have theorized, but not proved , that the ECUs capacitors might be falling in efficiency, making a older battery even more of a problem.
BTW, the P1621 is apparently related to the immobiliser system. We don't have that in the US, but that might be related to your cold crank problem. The battery, or the key switch... there is a "side to side" movement of the switch that activates the transponder reader. As I said, we US guys won't be able to help you with the diagnosis of that, but some of the other forums with more Brits have some more information.
Old Jan 31, 2016 | 03:30 AM
iconic's Avatar
Tried her this morning and all OK, was a low battery, thanks guys
Old Mar 3, 2016 | 01:51 AM
iconic's Avatar
Sorry, forgot to add a resolved this thread...the problem came back even with a new battery...maybe a new battery just masked the problem a little, it was simply down to stiff door locks components maybe down to lack of use of my Jag'
I stripped all the doorcards off the doors (and boot lid) and drowned the door and boot lock actuators, all and any moving parts in WD-40 (and some that didn't!) greased the operating rods before refitting and all is OK now.
Didn't take too long, maybe an a couple of hours max', but before pulling door cards do have some spare door card bushes and pins, I have the correct tools to pull the cards but still broke a few.
Hope this helps someone
caldercay
Sep 17, 2022 07:59 PM
jagnew
Jul 22, 2017 07:45 AM
Lord Donnington
Jan 24, 2016 01:21 PM
gimenofm
Jan 19, 2016 08:53 AM
2010 Kyanite XFR
XE ( X760 )
Jan 16, 2016 02:35 AM
