Changing Belts
Old Mar 14, 2013 | 10:55 AM
awil's Avatar
Default Changing Belts
how hard is it to change the 2 V belts on my 1996 XJ6? anyone have any good pictures of the process
Old Mar 14, 2013 | 06:52 PM
About 30 minutes, tops.
Loosen the 10mm bolt in the centre of the a/c idler, and use a 6mm on the square adjuster bolt facing the ground, remove that belt.
Undo the inner locknut at the alternator adjuster, 14mm,, wind the outer nut down the threaded rod, thus releasing the belt tension, remove that belt.
Refit is obviously the reverse. DO NOT overtighten those belts, and CHECK then after about an hours running.
Also check the idler pulley, it is possibly PLASTIC, and I would replace it. I use a steel aftermarket with a replaceable bearing.
I also remove the fan assembly, 2 bolts, 2 connectors, and lift out, much more room.
Old Mar 16, 2013 | 09:00 AM
awil's Avatar
thanks Grant I appreciate it
Old Mar 19, 2013 | 06:24 AM
mikesmith2's Avatar
I've just replaced my belts and I found that the square on the bottom of the a/c pulley adjuster is 1/4 inch.
So I used an 8mm 1/4 drive socket put the square end on the adjuster and my 1/4 drive ratchet in the 8mm end.
Old Mar 20, 2013 | 06:27 AM
awil's Avatar
Thanks mike great info.......I found out through trial & error
silkcat
Jan 18, 2025 04:29 AM
mrplow58
Jan 21, 2024 05:53 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
