Check Engine Light and Restricted Performance Light
Old Dec 27, 2012 | 11:40 AM
bigevent's Avatar
Default Check Engine Light and Restricted Performance Light
I had a post last week about these problems. I replaced the air filter and cleaned the MAF with MAF Spray. The Jag appeared to be running great then two days ago the light and Res Perf Light came on again. I did get a Diagnostic and the codes read
SHRTB1S2 1.6 ?
MAF 0.743 to a 0.754 ?
LONGFT2 ?
Do you guys think replacing the MAF Sensor would take care of my problem? to me it appears it all is relevant to fuel mixture.
Old Dec 27, 2012 | 01:19 PM
RJ237's Avatar
One of the more experienced members is going to ask you to post the actual codes so they can look for additional possibilities.
Old Dec 27, 2012 | 01:41 PM
bigevent's Avatar
Default OBDII Codes read
P1000 is the only code and reads "DTC definetly not found please refer to vehicle service manual" it did have a ? below the code. Any idea's?
Old Dec 27, 2012 | 03:04 PM
RJ237's Avatar
That means you have cleared all codes and internal checks are incomplete. It will become P1111 after a few drive cycles.
Old Dec 27, 2012 | 03:27 PM
bigevent's Avatar
Default drive cycles
Thanks, I'll repost soon.
Old Dec 31, 2012 | 05:22 PM
bigevent's Avatar
Default New Codes, Please help
Hey guys, I finally was able to drive a while. The check engine light is not on but the restricted performance pops on. I ran the OBD and came out with:
P1638
P1642
02 Bank2 Sensor1
Any ideas?
Thanks for all the help
Old Dec 31, 2012 | 05:29 PM
Suede's Avatar
This prior post references those 2 codes: https://www.jaguarforums.com/forum/x...-1642-a-26686/
BrentGardner
29
Dec 16, 2024 12:13 AM
lee,lee
Aug 31, 2015 04:35 PM
daro31
Aug 27, 2015 09:26 AM
Terrance Williams
Aug 26, 2015 11:50 AM
NinoGrimace
Aug 26, 2015 05:15 AM
