Clear fluid leak?
Old May 17, 2024 | 09:38 AM
PBoudr's Avatar
Default Clear fluid leak?
I may be over reacting but I've been monitoring a power steering fluid leak and today after going out for a drive I noticed a stream of fluid coming out from under the car. I can't pinpoint where it's coming from but it's a clear fluid that I believe is water. Hopefully just AC condensation. Is there a typical place that drips out of? It's currently dripping down a couple of feet behind the front tires. It looks like it's evaporating so I'm pretty sure that must be it. It's got me paranoid because I was just about to go on an hour and a half trip is a little while.
Old May 17, 2024 | 10:29 AM
Parker 7's Avatar
Run the car around with the A / C off and there should be no condensation dripping from the evaporator / heater core / matrix area
You can pull a fuse to ensure the compressor is not engaged
If radiator fluid will have color and bittersweet taste and slippery
I have another car that has a partial blockage of the evaporator drain line flow rate that once at a stop finally will drain out a lot of backed up condensed water , scarry
Old May 17, 2024 | 10:52 AM
PBoudr's Avatar
Thanks for the reply. It evaporated so that's got to be what it was.
Mandybxk8
Jul 25, 2023 04:01 AM
goldgun
Jul 19, 2019 07:28 PM
khsjsilver
Jul 10, 2019 01:51 PM
lynnpt2001
Dec 19, 2016 01:23 PM
climberman
May 9, 2011 09:46 PM
