Cold start problem aj16 x300 3.2 - RESOLVED!
Old Feb 4, 2019 | 12:48 PM
Don B's Avatar
Originally Posted by Paulofvfreitas
found this check valve, https://www.ebay.com/itm/Sytec-8mm-F...BB5:rk:15:pf:0
ti says "viton seals" i cant find nothing that says fluoroelastomer !!
Viton is a brand name of a rubber/fluoropolymer elastomer compound that is resistant to petrol/gasoline/diesel fuel, so that check valve should work.
Regarding the location of the valve, if I recall, on the X300 the lines coming from the tank to the fuel filter are rigid, so I would try to find a section of flexible hose in the engine bay leading to the inlet of the fuel rail (near the firewall). If you find a flexible section further rearward between the filter and fuel rail, that would work too, but off the top of my head I think that entire stretch of fuel line is steel.
Please keep us informed.
Cheers,
Don
Old Feb 5, 2019 | 11:53 AM
Paulofvfreitas's Avatar
Thanks Mr Miyagi (aka Don B) Will give that a try and post here the result. Have already bough the check valve so just wait for it to arrive.
Old Feb 7, 2019 | 11:20 PM
Jagboi64's Avatar
There is a flex section there, but it is very difficult to access. The fuel lines come through the trunk/boot floor right above the differential in the rear suspension. You also need the special disconnect tool to get the lines out of the tank.
Old Feb 7, 2019 | 11:59 PM
Jagboi64's Avatar
This is inside a twin pump XJR tank, but the single pump tanks are similar. The check valve is at the arrow in red. To access this the tank needs to be removed and the feed and return lines disconnected from underneath and the large plastic access panel on top removed.
Old Feb 18, 2019 | 04:56 AM
Well, while waiting for the check valve to arrived other items i ordered were arriving. So friday an ignition coil i ordered arrived to swap for the broken one i had on the 1st cyl. After installing the new one the car has been starting always at first/second crank.....
weird! I’m not throwing a party just yet but it seems to have cured the problem?!
Old Sep 29, 2020 | 04:06 PM
Well just to close this thread i wanted to post here that this problem was cured by changing the injectors!
after 1000km i had no more problems with this after changing all 6 of them
Old Sep 29, 2020 | 05:11 PM
Don B's Avatar
Hi Paul,
Thank you for reporting back with your success story! I have marked your thread RESOLVED!
Cheers,
Don
Old Sep 30, 2020 | 03:30 AM
  #28
countyjag's Avatar
Always great to see a problem resolved, but for future reference, are we concluding that fuel pressure was being lost through leaking injectors? An interesting possibility, or could it have been leaking injectors flooding the cylinders?
Im not trying to look a gift horse in the mouth, but am genuinely interested, as this seems to be a "new" type of failure for these cars.
Old Sep 30, 2020 | 03:54 AM
well cant say for sure but after changing everything else and because i also had a rough idle,due to this we change the injectors for some used ones and cured not only the rough idle but also the start problem. We didnt expect to cure the starting problem....
alec
Apr 20, 2022 03:44 PM
EJ Garity
Dec 31, 2014 10:57 AM
chater210
Feb 12, 2014 11:44 AM
Turbo_dash
Oct 9, 2012 06:28 PM
Censport
May 10, 2010 04:44 PM
