Cooling fan loom repair/replace
Old Jul 1, 2024 | 11:24 AM
vantveer's Avatar
Default Cooling fan loom repair/replace
An old cable-tie failed and the cable to upper fan got trapped between fan shroud and crank pulley, shorting the circuit and blowing f11 fuse. Luckily I noticed the temp creeping up and not far from home.
Anyone repaired one of these or have suggestions on correct gauge wire to repair? It's multi-strand and a 30A circuit for that fan.
f17 for other fan is OK and hoping fan control relay is OK.
Otherwise got to find a replacement
Old Jul 1, 2024 | 11:46 AM
Parker 7's Avatar
If you have enough wire left there are waterproof butt splices that you wouldn't need special tools for ( Kansas City electronic supply store )
Fan control module should be OK but if replaced it is a white one and not black for the slightly different system on the V - 8 ( X308 )
There is a simple paperclip test for the fans as you put it back together ( low current section of the fans circuit ( it also test the fans control module )
Old Jul 1, 2024 | 05:26 PM
vantveer's Avatar
Great idea Parker! worked like a charm. Thunderbirds are go again
Old Jul 1, 2024 | 06:07 PM
Parker 7's Avatar
Simple as 5..............4................3...............2. ................1
Oh Parker
JigJag
Jan 3, 2021 10:22 AM
snepo
Jul 21, 2018 09:29 AM
v1rok
Jul 1, 2018 10:02 PM
Rhett
Oct 23, 2015 03:25 AM
Terry
Apr 29, 2012 08:54 AM
