Couple questions about illumination
Old May 16, 2014 | 02:14 PM
jeepzj94's Avatar
Default Couple questions about illumination
Hello,
I just bought my first Jaguar last week. It has 262k miles on it, but it has been wonderfully maintained and taken care of and runs and drives like a dream!! I was curious though if the digital odometer/message center is supposed to be lit? Cause at night with the lights on, mine is not lit at all. I assume its just 1 or 2 bulbs if it is supposed to be lit? The rest of the cluster is lit and looks good with no dark spots. And the second question, is the PRND32 pattern supposed to be lit? Mine shows red on the gear that I've selected, but the rest is dark. Thanks!
Old May 16, 2014 | 05:14 PM
Suede's Avatar
Yes, the odometer/message center is indeed supposed to be lit. The cluster must be removed to change the bulbs. I've listed instructions for replacement in the following thread:
https://www.jaguarforums.com/forum/x...ng-dark-89944/
Old May 16, 2014 | 05:52 PM
jeepzj94's Avatar
Perfect, thank you!! Are the bulbs a specialty item, or can they be purchased at any auto parts store??
Old May 18, 2014 | 06:18 AM
SleekJag12's Avatar
The trans panel illumination is from one bulb, located at the forward part of the shifter, and under the trim pad surround. Carefully remove the black ring and then the leather surround by releasing the plastic tabs. The bulb is small and a little tricky to get a grip on.
The bulb is GE 32, Rock Auto has them. I dont know if auto parts stores would, but I doubt it.
Also, the light will appear as off white, not green as original, because the new bulbs are clear not coated. But it's still pleasant, and better than dark!
Old May 28, 2014 | 08:33 AM
jeepzj94's Avatar
Thanks for the help, got them all replaced. Now onto the climate control and clocks lights, as they mysteriously burnt out now. Does anyone know if there is an aftermarket twist lock base that works for those particular holes so that I can add aftermarket lights like from autolumination or superbrightLED's??
Old May 28, 2014 | 10:28 AM
al_roethlisberger's Avatar
If I recall, there is a thread for replacing the instrument incandescent bulbs with LEDs that includes pretty specific DIY instructions with photos, etc. So it definitely can be done. I'd do a search for LED or clock/HVAC lighting.
Old May 28, 2014 | 12:44 PM
AlbBolivar's Avatar
So there should be two different bulb colors in the shifter column? I have the same where the gear selected is red but all other gears are just dark. I always thought it was defaulted like that
Old May 28, 2014 | 01:04 PM
jeepzj94's Avatar
Yes, there is a single bulb at the front of the shifter, underneath the black and leather trim pieces that should light the shift pattern.
Old Jun 8, 2014 | 11:11 AM
Question
Heh, I guess I am just not following here
So, my J-Gate has one light in it, even with the headlights turned on. "Red" under the selected gear.
Should the whole J-Gate (unselected gears) instead ALSO be illuminated white/green with the headlights turned on?
Old Jun 8, 2014 | 07:50 PM
SleekJag12's Avatar
Yes! See post #4. That little bulb needs replacing on most cars by now.
Old Jun 8, 2014 | 08:23 PM
Lightbulb
Thanks for the clarification
I'll take a look at the bulb while I'm in there removing the radio to be sent off for repair!
Old Jun 8, 2014 | 08:55 PM
BTW, here's another thread on the same subject:
https://www.jaguarforums.com/forum/x...l-light-42381/
And a photo from our own DD
Welcome to Jag-lovers - Members Photo Viewing Page
H20boy
Dec 24, 2024 03:23 PM
WinterJag
16
Oct 9, 2015 07:49 PM
teacoff
Sep 10, 2015 08:25 AM
Mosers63
Sep 6, 2015 02:53 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
