Cruise control
Old Jun 8, 2019 | 04:04 PM
Stu Jags's Avatar
Default Cruise control
My cruise control doesn’t work, any suggestions what might be wrong / not working?
Old Jun 8, 2019 | 05:19 PM
Lady Penelope's Avatar
Leak check the diaphragm in front of the butterfly shaft tower
Th rubber is getting old
https://www.jaguarforums.com/forum/x...-today-120408/
Old Jun 8, 2019 | 05:25 PM
Stu Jags's Avatar
The diaphragm had holes in it but I fixed with bike inner tube repair patches. Where does vacuum come from to work diaphragm. I read it’s electric pump under air filter?
Old Jun 8, 2019 | 08:25 PM
Yes ' it's the oval thing under the air filter
Old Jun 9, 2019 | 08:02 AM
Stu Jags's Avatar
Have looked over cruise systems. Fuse good, red light comes on when selecting cruise. Vacuum had holes in but have repaired. Blanked dump valve and test drove, still no cruise. Could it be pump ? Can I test with 12 v feed ?
Old Jun 9, 2019 | 11:00 AM
There is a CC inhibit if the traction control is commanding the rear wheels to reduce spin rate
Looking into a test procedure since you have the valid light which is good
Old Jun 9, 2019 | 11:16 AM
Look at page 91
http://www.jagrepair.com/images/Auto.../jagxj1995.pdf
Your valid light is the LED diode in the cruise control switch pack
A cleaner diagram on the 1996 is on page 104
http://www.jagrepair.com/images/Auto.../jagxj1996.pdf
Is the vacuum pump cylinder body warm to the touch ? It seems to run at all times when CC engaged
Is the hoses attached on the nearby dump valve ?
Anti lock brakes and traction control working along with speedometer working as the speed input is the left rear wheel speed sensor ?
The brake switch from reading gives problems and has been upgraded by a TSB . Can you remove the ground ? This would keep the CC engage in a emergency brake pedal application
http://www.jagrepair.com/images/TSB/...l%20Switch.pdf
There are 2 switches in the assembly , one to run the tail lights
Editing
Old Jun 9, 2019 | 02:55 PM
Stu Jags's Avatar
abs, speedo, traction control all working as it should. I blanked dump valve to eliminate. I don’t think vacuum pump runs at all. Can I put 12v feed to pump to see if it runs ?
Old Jun 9, 2019 | 02:58 PM
Stu Jags's Avatar
ABS etc working ok. I blanked dump valve to eliminate. Don’t think vacuum pump runs, can I run 12v to it and see if it works?
Old Jun 9, 2019 | 05:31 PM
Positive is on the purple / green wire and ground is the blue / yellow wire at the vacuum pump / control valve connector
You can use a battery charger on the low amp setting or pull power from the + terminal post of the LH engine fuse box and there is a ground stud on the chassis rail near the area of interest
Old Jun 10, 2019 | 03:22 PM
Stu Jags's Avatar
Battery charger on vacuum pump made a clicking sound but created no vacuum so I guess pump is dead ? How long should bellows hold vacuum. If I squeeze bellows and then place thumb over outlet the bellows open fully in 1-2 seconds. Possibly bellows and pump to replace?
Old Jun 10, 2019 | 08:44 PM
The pump may be frozen bearings that may be opened up and physically rotated to free up and reoiled
By the pump twerking by feel in your hands indicates the motor electrical windings are probably intact
Just guessing if that can be done
The diaphragm has a glue around the metal seam that may have become brittle and leaking
Old Jun 11, 2019 | 02:34 PM
Stu Jags's Avatar
Good news I got vacuum pump working and creating a vacuum. Blue yellow wire positive, purple green negative. Bellows is U/S so used item on order from e bay.
If I want to test the pump is working on the vehicle should it pump as soon as cruise is turned on or will it only pump when travelling at more than 25mph as that’s min cruise speed ?
Old Jun 11, 2019 | 08:10 PM
Try a hilly / changing road
The wiring guide and the breakout sheet page before at 103 on pin 20 for the 1996 is wrong then
I would assume the pump will not turn on until commanded by the switch hence wearing something out when not in use unless the pump has a slow build up time for a quick responce
Old Jun 12, 2019 | 12:49 AM
Stu Jags's Avatar
I’m going to jack up the back end and get some one to drive over 25 mph while i check the pump engages when turned on.
Old Jun 12, 2019 | 05:55 AM
There is a TSB on running up the engine in park position
I think it has to do with transmission cooling
Old Jun 13, 2019 | 03:16 PM
Stu Jags's Avatar
That’s the cruise sorted, bellows replaced and pump freed off.
Old Jun 13, 2019 | 03:33 PM
Vee's Avatar
Vee
What was that? I have no idea what this means.
Old Jun 13, 2019 | 03:46 PM
Stu Jags's Avatar
Vacuum pump had stopped working, so I removed and freed off. Bellows is what vacuum pump controls and so maintains pre selected cruise speed.
Old Jun 14, 2019 | 07:57 AM
How did you free up the vacuum pump ?
Others may want to know
