D/S Master Window Switch Repair
Old Jan 6, 2011 | 07:06 PM
cooke's Avatar
Default D/S Master Window Switch Repair
Is there anyway to fix or repair a drivers side master window switch?
Old Jan 6, 2011 | 08:46 PM
Oubadah's Avatar
Depends what's wrong with it. You won't know until you take it apart. The interior door trim panel must be removed and disassembled to get to the switch box.
I had mine apart to access the backlights:
2 = The mystery mirror control backlight (why didn't they make it accessable like the other two/three)
3 = Contacts for backlighting whatever extra controls are included in high spec cars. This has an access hole included in such cars (mine just has the depression where the hole would be)
1 = I wonder what this thing is??? it certainly isn't an active backlight...
reverse:
Old Jan 6, 2011 | 09:37 PM
Doug's Avatar
The pics are very helpful to me as I've been meaning to open up my switch. Now I know what to expect :-)
The problem with mine is the "left-right" button for the electric mirrors won't hold position.
Old May 2, 2016 | 05:29 AM
julien4020's Avatar
Hello Oubadah !
I am aware this post is almost 5 years old but I am facing the same issue with my master switch. The miror switch is broken and I would like to fix it by dismanteling the whole switch an then trying to recreate the broken button.
When I try to separate both parts of the black plastic casing, there is a strong resistance and I can not seperate it.
I do not dare force for fear of breaking everything... The part is bloody expensive !
Do you remember how you manage to seperate yours ? Did you have to force or disconect something before taking apart the 2 black plastic casings ?
Thanks a lot for the help !
Julien4020
Old May 9, 2016 | 05:03 PM
smartobject's Avatar
The pictures show a white rubber strip going around the middle of the unit - this can be sliced lengthwise with an xacto knife / razor knife.
Also - I'm pretty sure there is a screw in the center holding the two sides and you need to poke through a round paper / plastic sticker to reveal that screw head.
I wanted to do the same, but ended up replacing the whole thing. The joystick is a thin rod of clear acrylic - I tried glue and plastic-welding, still no go.
If I could compare the pins with the X308, I would love to swap for that - just a flat pad instead of the joystick?
Although the unit is not compatible with the XJ40 years, the joystick part looks like it's the same - I think those are less expensive from used resellers.
Old May 10, 2016 | 04:53 AM
julien4020's Avatar
Hi smartobject !
Thanks a lot for the answer.
I have noticed a small sticker at the back of the switch. That might be the one hidding a screw
I will try what you said this week-end.
I would like to fix it because I am located in France and these cars are pretty rare, especially with high specs, and cheap switches coming from UK are not compatible ... (LHD Vs RHD)
I will keep you informed !
Best regards
Julien
Old Jun 13, 2016 | 05:07 AM
julien4020's Avatar
Dear All,
Just to keep you updated, I have finally managed to repair my master switch !
I have disassembled the master switch following the indication you gave me.
Then, I filled the transparent bezel with epoxy glue. That worked great.
Then I carefully drilled a 3mm hole and inserted a 3mm nail.
I did the same on the knob.
Here is a picture. It now works great and costs nothing ! Just the way I like
Old Jun 14, 2016 | 06:39 AM
Maraud's Avatar
The number 1 in your picture is for the led for memory options when you have this.
I have a led there on my remote control and some buttons; 1,2,3 and set.
99xk8guy
Sep 29, 2025 10:51 PM
kevinl
Oct 31, 2019 06:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
edtexas
Sep 5, 2015 10:49 AM
