dealer shutoff
Old Apr 4, 2010 | 03:48 PM
mvagts's Avatar
Default dealer shutoff
I took my 1997 jaguar xj6 to the jaguar dealer a while back and they did something to shut off the entire power to the vehicle. The battery is fully charged so i am wondering what they did because i'm looking to fix it up, please help.. Thank You
Old Apr 4, 2010 | 06:49 PM
Thermo's Avatar
Veteran: Navy
mvagts, about the only thing that they could have done was either cut the battery cable or they disconnected the main wire inside of the fuse box.
I would also check the main line fuses to see if they are good. These are 250 amp fuses (yes, 250). Two of them should be really close to the battery, the other one is going to be located near the right hand healboard fuse box. If these are blown, then obviously you will get no power in the car.
Just to make sure that we are talking the same thing. When you say no power, you are saying that nothing works, not a dome light, no chimes, NOTHING. Or do you have power to some things, but not all things. By knowing what has power and what doesn't, that can help me look at the drawings and be able to narrow down where the problem may lay.
Old Apr 4, 2010 | 07:56 PM
mvagts's Avatar
Yes nothing in the car works; lights, and everything. I will check the other solutions that you have provided. thanks
Old Apr 4, 2010 | 08:01 PM
mvagts's Avatar
chris- where is the fuse box located in the car?
Old Apr 4, 2010 | 09:26 PM
eaglexkr's Avatar
Question
Since you a new member,read the user CP,and FAQ,don't start a new thread on the same problem.
Old Apr 5, 2010 | 02:54 PM
Thermo's Avatar
Veteran: Navy
mvagts, open up your trunk and look under the carpet on the right hand side (as you are facing the front bumper). You should see a box on the there near the back edge of the wheel well (possibly in the spare wheel well). This will have the two 250 amp fuses.
As for the single 250 amp fuse, you will need to remove the right rear passenger seat. The fuse is located under the seat. You should see a good size wire there and it will be in that line. If you can, take a multimeter to each side of the fuse to verify that you have power in and out. If you don't have 12 VDC on both sides of the fuse(s), then you know the fuse is bad.
Old Apr 6, 2010 | 04:27 AM
I'm not going to be able to offer any electrical advice, Thermo is your man for that.
But where is the car now, if you took it to the Jaguar Dealer, and then had this problem appear? Which you say they introduced, surely it is still there?
Cheers,
Old Apr 6, 2010 | 07:41 AM
steve11's Avatar
ud
Just curiosity. Why would the dealer disable the car? Do you not have the option to take it back for a repair? On the X300, there are a number of fuse boxes, one in the trunk, one in the engine compartment, one behind the heelboard of the rear seat.
The very first main power distribution fuse is directly off the battery and is a 500A fuse located off the positive cable of the battery and housed in a plastic case. This would be the starting place before the 250A fuse in the back seat. The 500A fuse shouldn't blow unless it was a defective fuse in the first place. It would take some catastrophic event to blow it, like bridging the positive/negative terminals, or hooking up a booster in reverse.
If the car has never run since the dealer worked on it, this fuse could have been removed (although I don't know whay they would) and not replaced.
JarodL
Mar 7, 2024 01:39 AM
perfectson
Nov 1, 2015 10:46 AM
Marco Polo
Oct 1, 2015 07:13 PM
Holden
Sep 5, 2015 03:29 AM
