Decklid dashboard light intermittently comes on, then off. With lid closed.
Old Feb 17, 2023 | 02:00 PM
tompullizzi's Avatar
Default Decklid dashboard light intermittently comes on, then off. With lid closed.
Hi!
my car is now my daily ride, (6 miles each way), since I spun around my 87 BMW on wet pavement (stupid), and ripped up my radiator support, so that has to wait for spring.
but I read all the new posts, and am grateful for them.
question: how does the car sense an open decklid? I don’t see a contact switch anywhere. The light has a mind of its own, and my doorlocks work when I take the car out of Park, but pop open sometimes when I try to lock them with the button in the front door.
I still have no alarm fob, so still trying to lock the door with the key, which only works once in a while. I’m thinking even if I got a used fob, it would have to be programmed by a dealer, so $$$ not right now.
wondering if that stops my doors from locking with the key.
thank you,
tom
Old Feb 17, 2023 | 05:40 PM
Parker 7's Avatar
A common thing with the trunk lid light is worn wires under the curved plastic cover on the car's right side trunk hinge arm
The wire colors are X and Y
editing
The FOBs come in 2 frequencies . 315 and 433 hz
you can look at the car antenna and tell the difference
Key Remote Fob for XJ6 XJR XJ12 X300 - Page 6 - Jaguar Forums - Jaguar Enthusiasts Forum
There are plenty of instructions ( and TSBs starting with section 18 numbered ) on how to program the FOB
JagRepair.com - Jaguar Repair Information Resource
when the Fob is fully working it will make chirps in this video in the security section in minute 6:38 and the chirp speaker can be broken
Old Feb 17, 2023 | 07:00 PM
watto700's Avatar
G’day Tom,
The trunk/boot lid micro is part of the latch and sometimes the little plastic operating rod beaks off, or the switch needs to be lubed, giving you the indications you have.
If the switch gives a faulty ‘open’ signal then the car won’t centrally lock and the trunk/boot light will remain on.
Cheers,
Jeff.
Old Feb 18, 2023 | 11:13 PM
SleekJag12's Avatar
And if the trunk switch pops to "open trunk" when the car is locked and armed, you will get the obnoxious Alarm Mode. Turn the key to ignition ON to stop and reset an active alarm sounding (USA models).
I replaced the rare "trunk latch switch" with a magnetic reed switch mounted along the trunk liner. It works just fine.
Remotes for these cars do not need programming from a dealer. A dealer will not know what to do with one of these. Programming is DIY. The hard part is finding a good remote.
Watch out for slippery roads, the X300 can get away from you too. Although its bulk helps with traction. Hope the classic Bimmer will be ok.
Old Feb 19, 2023 | 06:58 AM
Default Thank you! Trunk Release button also on the fritz.
Yes, it was a rainy day, close to freezing with that BMW. Thanks for advice on the Jag. I’m extra careful after my wreck.
forgot to mention the Trunk release button does nothing.
Happy Motoring
tom
mikesbaron
Mar 6, 2023 08:48 AM
wierciu
Jul 4, 2022 12:01 PM
acharner
May 27, 2022 04:23 AM
spanky145
Dec 29, 2017 03:06 PM
seagoon
Feb 10, 2016 11:54 AM
