DIY Modification to Improve Performance and Fuel Economy of AJ16 and AJ6 Engines
Old Jul 27, 2016 | 09:45 AM
  #461
cdma's Avatar
Originally Posted by XJRengineer
I am extremely sorry that you have had a bad experience with one of my brackets. I have checked all of the remaining brackets that I have in stock from the current batch. As you say, the sensor hole is undersize. It should be 17mm, but it is only 16.8mm on all the brackets that I have checked. Thank you for bringing this to my attention. Please contact me directly and I will arrange to reimburse you for the cost of your broken sensor. Please also return your faulty bracket and I will send you a replacement. In future, I will implement a 100% check on the hole size of all brackets prior to shipment.
To anyone else who has recently purchased one of these brackets, please do not try to force the sensor if it does not fit. Please return any brackets with undersize holes and I will exchange them for brackets which have been 100% checked for size before shipping.
Once again, I sincerely apologise to anyone who has been inconvenienced by this quality issue. This is the first time we have had any quality issues with these brackets in a production run that now totals 500 parts.
Although I had issues with the bracket I must say I had the best customer experience with getting the issue resolved. I just wish other companies we as easy to deal with as XJREngineer. Thanks again for all your help. I can't wait to get my new bracket.
Old Aug 11, 2016 | 05:06 PM
  #462
michaelmedina2005's Avatar
i just installed my,"andy bracket",yesterday,wow!,new zip to the 20 year old cat..thank you very much for a great product andy
Old Sep 3, 2016 | 11:49 AM
  #463
XJRengineer's Avatar
Thanks for the positive feedback on the bracket. Much appreciated
Your car is looking great, particularly the wheels. Have you had them refurbished?
Old Sep 3, 2016 | 09:18 PM
  #464
I used mothers metal polish and sanding disks on a foam pad on my drill, started with 1000 grit,2000,3000,and ended with 5000.lots of work, but worth it, since it is unsealed,i have to touch-up every two months
lots of work,but worth it
Old Sep 3, 2016 | 09:24 PM
  #465
My next project is to make my own poly bushings from molds for both sway bars and drop links, and drop link eyes
Old Sep 4, 2016 | 02:22 PM
  #466
I fitted uprated front sway bar bushes, but I have an alternative suggestion to uprating the bushes in the drop links, as we have already discussed off-line. I replaced the standard Jaguar drop links with ones of my own design. These use high spec spherical bearing rod ends joined with a turnbuckle. The rod ends are enclosed in rubber boots. I use conical misalignment washers to allow the spherical bearings to fully articulate. The combination of the rod ends that I selected and the misalignment washers very closely match the width of the standard drop link ends, so the standard bolts can still be used. I don't find that the use of spherical bearings has any negative effect on ride quality. However, it significantly increases roll stiffness of the car by eliminating all the compliance present in the bushes in the standard Jaguar drop links. I would thoroughly recommend this modification if you want to improve the handling of your car.
Old Sep 8, 2016 | 06:36 PM
  #467
wayland's Avatar
Andy, do you supply these drop links yet?
Old Sep 10, 2016 | 01:24 AM
  #468
Yes, I've been offering them for years. See separate thread titled "Andy's front drop link experience". Please can you post any further questions there. My fault for leading this thread "off-topic".
Old Sep 10, 2016 | 12:15 PM
  #469
XJ-Executive's Avatar
Lightbulb
hi, i'm hoping to get one of these but i'd like to ask if it's possibly to use less metal and make it lighter?
the main body of the bracket, around the bolt holes, have a sharp corner, could they not be rounded off? what about the metal inbetween the two bolt holes, could we narrow that and introduce a waistline?
i appreciate this is a very insignificant point but i think we could shave off some metal here! (obviously we cannot weaken it).
Old Sep 11, 2016 | 04:37 AM
  #470
My bracket weighs 60g and a standard bracket weighs 30g. My brackets are machined from a solid block of aluminium. I needed to create the shape with the minimum number of surfaces in order to minimise the machining time. I could design a bracket that looked more like the shape of the die-cast standard part, but it would cost very much more to machine each one. I don't think anyone would consider it a good weight / cost trade-off.
Old Sep 11, 2016 | 06:29 PM
  #471
Talking
that makes sense, we don't want it any more expensive
Old Oct 3, 2016 | 07:38 PM
  #472
VancouverXJ6's Avatar
If anyone wants to buy one I have a 'andy' bracket EBC1253, sold my xj6 and didn't need it anymore - at cost same as I paid minus shipping from the UK.
Old Oct 8, 2016 | 02:29 AM
  #473
Dear All,
I just collected from the machine shop the new batches of revised crank sensor brackets for replacing both the EBC1253 and EBC5017 designs. These brackets are for early AJ6 (post 3.6L engine number 108834) and late AJ6/all AJ16 respectively. The changeover on bracket design occurred on late 3.2L/4.0L AJ6 engines at engine number 161586. If you are interested in one of these brackets, then please contact my wife Helen using her email helenstodart@gmail.com.
Thank you all for your continued support for my revised brackets.
Old Nov 7, 2016 | 03:15 PM
  #474
The last batch of brackets had almost all gone, but I collected another batch from the machine shop today.
Old Nov 17, 2016 | 03:49 PM
  #475
Stevie b's Avatar
I purchased one this yr fitted it and now reading this post mine was a very very tight fit I cleaned up sensor and greased and got it in just! Cars Is in body shop now so haven't got acsess to car at the moment
Old Nov 27, 2016 | 10:03 AM
  #476
Tcasmarcus's Avatar
Oh my God. .. What a fantastic engine response after installing this. It took 10 minutes. And I'm no mechanic. Feels a lot quicker and I am quite sure it actually is.. thanks!😊
Old Dec 29, 2016 | 05:50 AM
  #477
Thanks very much for your positive feedback.
There are now over 550 Jaguars fitted with these brackets.
Old Feb 14, 2017 | 01:42 PM
  #478
We still have plenty of brackets in stock, for anyone who hasn't tried one out yet.
Old Feb 14, 2017 | 06:02 PM
  #479
xxxscimitarxxx's Avatar
another thumbs up for the bracket.....my car has had one fitted from when I bought it so it was never easy for me to say how different it was from another car that didn't have one....until last weekend when I had the chance to drive another manual XJR6 that wasn't fitted with one...and I can certainly say my car felt a tad quicker through the gears ....its a must have for the AJ16
PS to Andy......can you still re map auto ECUs for manual configuration.....please PM me
Old Mar 5, 2017 | 08:47 AM
  #480
Tcasmarcus's Avatar
I found a straight flat empty piece of road so I had to give it a test. 1 attempt only and I have a small exhaust leak so there is room for improvement.
Very pleased with engine response etc.
1995 , 4.0 sovereign
