DIY: X308 Washer Tank conversion
Old Mar 4, 2021 | 02:51 PM
xalty's Avatar
Default DIY: X308 Washer Tank conversion
Accidentally blew your washer tank to pieces? No problem
Parts needed: Washer tank assembly from X308
GM 6-700 Washer Pump with connector: https://www.ebay.com/itm/264600374798
Step 1: Remove filler neck, jack up right front.
Step 2: remove 4 10mm bolts securing tank to the car
Step 3: remove level float connector (red), pump connector (black) and pump hose
Step 4: Install washer pump and included grommet into new tank as shown
Step 5: cut level float connector wires and splice together.
Step 6: cut factory washer tank connection and connect new wires. red to black and blue to yellow
Reinstall.
Old Mar 4, 2021 | 02:56 PM
xalty's Avatar
use some glue or a cap to plug the nipple on top
Therock88
Sep 12, 2024 01:58 AM
OldMike
22
Nov 16, 2013 06:32 PM
henry k
Nov 10, 2012 10:46 AM
fonewiz
May 12, 2011 06:18 AM
Stu 1986
Jun 13, 2009 05:19 AM
