Dodgy Number Plate Light
Old Mar 11, 2012 | 07:38 AM
Car-Nut's Avatar
Default Dodgy Number Plate Light
My right hand side number plate light is being tempremental.
When its closed it doesnt work, when the boot is open it does,
when you close it and get to 45 degrees it goes off, Ive had the boot lining
off and cant see any trapped, bent, loose wires
Any one got any suggestions ……
Old Mar 11, 2012 | 07:53 AM
Straight6DOHC's Avatar
The wire harness at the off-side boot hinge will be broken. Carefully, remove the ribbon of tape and search for your number plate lamp wires. You'll need to splice in some new wiring. If the harness is cable tied to the hinge, unclip the tie, and let the plastic trim hang freely. The harness need to be as free t o move as possible so as to not damage wires.
philwarner
Oct 4, 2024 01:37 PM
Jpav27
Jul 31, 2022 06:43 AM
user 652867429824
Oct 28, 2015 10:18 AM
redrover41
23
Sep 25, 2015 01:33 PM
KarimPA
Sep 3, 2015 07:32 PM
