Door puddle light lens - how to install & remove
Old Aug 24, 2015 | 01:06 PM
al_roethlisberger's Avatar
Question Door puddle light lens - how to install & remove
While doing some other work on the car this weekend, where I was eye level with the bottom of the doors, I noticed that the passenger (RH) door "puddle" light lens didn't appear to be fully seated flush up into the door panel.
I pushed on it a bit and it seemed to 'click' in a little, but it bounced back out.
Before I pushed and tugged on it anymore and then succeed in breaking it.... can someone offer a quick "how to" on how this lens comes off properly, and similarly how it installs?
Old Aug 24, 2015 | 06:11 PM
b1mcp's Avatar
Al
On the front doors there is a plastic tang that holds the light. It can be accessed with a small screwdriver from the bottom of the light - there is a small access hole.
On the rear doors there is a quarter turn screw in the door pocket immediately above the light.
Old Aug 24, 2015 | 09:18 PM
Default Thanks, also found it in the manual
Heh, well this probably helps from the Vehicle Care manual!
Attached Thumbnails Door puddle light lens - how to install & remove-075.jpg
kurtomatic
Feb 12, 2024 06:58 AM
10 XF Premium
Sep 18, 2015 10:03 PM
jagent
Aug 30, 2015 08:42 AM
Jandreu
Aug 29, 2015 07:31 PM
stetson1
Aug 27, 2015 07:49 AM
