Doors won't lock
Old Mar 9, 2019 | 08:15 AM
hunterpedigo's Avatar
Default Doors won't lock
I have a 1995 Jag VDP, door locks, nor trunk locks, won't lock, I have checked the fuses, ect any suggestions?
Old Mar 10, 2019 | 11:37 AM
Vee's Avatar
Vee
How’s your battery. The power lock feature on my car begins acting strange, including not working, when the battery is about 6 months from its way out.
Old Mar 10, 2019 | 01:08 PM
Lady Penelope's Avatar
Fuse check list :
Relay check list :
Editing
Old Mar 11, 2019 | 07:44 AM
Battery is fairly new, about 1 year old all the locks are not working electrical.
Old Mar 11, 2019 | 08:00 AM
Vee's Avatar
Vee
So the locks will not work manually, or using the key fob? Lady P has certainly given you something’s to check. Relays and ultimately the security ECU.
Let us know what works and what doesn’t. Right now your description makes it sound like nothing will work manually or remotely.
Old Mar 11, 2019 | 08:37 PM
# 4 / 10 amp Trunk fuse box
pin position # 2 ignition switch provides a ground
pin position # 3 ignition switch provides a ground through the inertia ( crash ) switch
all door relays get there power from fuse # 1 / 15 amp RH heelboard fuse box
The trunk relay is # 8 / 15 amp Trunk fuse box
Since you have a issue with both trunk and doors this points in the SLCU direction
To trigger the SLCU there are 2 switches in the door lock that can be looked at with a meter
Beyond the electrical side there is the mechanical side where the linkage wares out not allowing the switches to do their thing
This area I have not tinkerd with but I've seen post covering the mechanical
Old Mar 12, 2019 | 04:01 PM
Goo info thanks
macboots
Oct 13, 2016 08:26 AM
bassmania
Mar 13, 2016 01:42 AM
Melandra Bethell
Jul 1, 2015 07:20 AM
jaguarlady03
Jan 30, 2013 10:20 AM
facet
Dec 15, 2011 02:50 PM
