EGR Temperature Sensor & occasional P0400
Old Jan 9, 2021 | 04:23 PM
Nobeel Masri's Avatar
Default EGR Temperature Sensor & occasional P0400
Hi,
I was getting an occasional P0400 EGR flow error even after replacing EGR valve from a working car. After recently replacing the exhaust manifolds and working with the EGR system, I knew that it was hooked up right and should be good, but it still threw a fresh P0400 code. I was also hearing a regular a knocking tapping sound, which I hoped was the old manifolds, but it was still there after replacing them.
I decided to take a look at the EGR Temperature Sensor and found it was really caked with carbon, see the pics
After cleaning with a wire brush I cleared the code and started the car. It was instantly much quieter and idled with barely a wobble on the steering wheel. Before you could really feel the engine idling,
I have driven around 100 miles since this and the car drives so much smoother and the engine seems a lot quieter than it did before. So far without a P0400 code
I couldn't find much on the sensor, so I thought I should share my experience in the hope it helps.
EGR Temp Sensor before
Godspeed
Apr 28, 2019 12:59 PM
NTL1991
XJ40 ( XJ81 )
Jan 27, 2017 10:41 PM
mynameismonkey
Aug 23, 2016 12:02 AM
genoaz
Sep 3, 2013 02:19 AM
Kirk511
XJ40 ( XJ81 )
Sep 11, 2011 07:04 PM
