2005 XJR P0400 (and P1000 pending) - safe to drive for a week or so?
Old Aug 21, 2016 | 12:04 PM
mynameismonkey's Avatar
Default 2005 XJR P0400 (and P1000 pending) - safe to drive for a week or so?
Hi all, took a short drive yesterday, 20 minutes, check engine came on, OBD shows P0400 and P1000, at idle. Revs are ~750 at idle. Recently had some hoses replaced on the cooling system, not sure if it's related. Anyway, before I start worrying about combustion temps, if I'm tooling around town for a few days before I can get to my mechanic this shouldn't be a major problem, right?
Old Aug 21, 2016 | 12:31 PM
gm_jim's Avatar
P1000 means a code has been set and will go away once the P0400 (EGR fault) is corrected. Freeze frame data would be helpful. The EGR monitor activates under deceleration when driveability isn't affected. The ECM commands the EGR full on and the MAP sensor looks for a pressure pulse in the intake tract. If a pulse is sensed then the EGR monitor sets good. No pulse generates a P0400 and P1000 and the monitor won't set.
In my case the freeze frame data indicated incorrect output from the MAP sensor. I fixed that and no further problems. The actual problem wasn't the EGR at all.
Old Aug 23, 2016 | 12:02 AM
BlackKat's Avatar
I drove around with the p0400 for a few months. I managed to somehow damage the egr when I replaced the valley hose. Got a new egr valve from partsgeek all is well now. Manifold leaks have been reported to throw egr code but is a rare occurrence. You may want to go ahead and replace the egr exhaust tube as well as they easily corrode or break.
Sep 17, 2019 09:27 AM
darrhel
Apr 9, 2016 04:30 AM
Dec 16, 2006 02:48 AM
Oct 30, 2006 11:24 PM
Feb 13, 2006 11:40 PM
