Engine Code B1315 B1316, Plz Help!!
Old Dec 1, 2009 | 10:44 PM
hatajay's Avatar
Default Engine Code B1315 B1316, Plz Help!!
Hi everyone,
I have a XJ6 96. The misfire during idle and low RPM has been a problem but the check engine light did not come out. Today it came out as for cylinder 4, and I will be replacing the ignition coil first to see if that fixes it.
However, they were two more codes which I got from the code list:
B1315 Battery Saver Relay Coil Circuit Short To Battery
B1316 Battery Saver Relay Coil Circuit Short To Ground
Everyone I asked seemed to have no idea what those are, can someone please help me? I would really appreciate it!! Thanks!!!
Old Dec 2, 2009 | 08:58 PM
hatajay's Avatar
well i will be replacing that first, but need to wait for the part to arrive. i can't afford $400+tax per coil at dealers.
besides replacing coil, what is other possible repair?
Old Dec 2, 2009 | 09:13 PM
sparkenzap's Avatar
do that first, then see what codes you get.
toronadomike
Jan 22, 2026 10:13 PM
philwarner
Oct 4, 2024 01:37 PM
Jpav27
Jul 31, 2022 06:43 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 2, 2015 12:48 PM
