Engine oil
Old May 6, 2021 | 02:28 PM
  #61
xalty's Avatar
Originally Posted by JezuzNoChill
Maybe some old mineral oil but most 10w-60 oils for sale now are fully synthetic "racing" oils which are going to hold their viscosity much longer than 20 feet.
all of them are loaded with VII. they shear to a light 50 fast.
Originally Posted by katar83
Pretty much every Jag garage(or dealers) in UK I can think off will always use 10w40 in every AJ6 or AJ16,
most 10w40s in the uk and europe are good oils, they are forced to be. american 10w40s are some of the worst oils you can possibly buy in the developed world.
Mobil 1 High Mileage 10W40 is an exception, it’s ACEA A3. the problem is it’s priced exactly the same as their 0W40 and many other A3/B4 offerings from Shell and BP.
Old May 6, 2021 | 04:13 PM
  #62
Vee's Avatar
Vee
Castrol Edge 0w40 is API SN/CF, ACEA A3, ACEA B3, ACEA B4, A3/B4 certified
….and down the rabbit hole we go!
Old May 8, 2021 | 01:04 AM
  #63
captainobvious1's Avatar
Well, I just changed the oil in my 1997 X330 (XJ6L) with Valvoline 5w-40 Pure Synthetic Engine Oil. I'm going to change it every 6,000 miles as directed.
Old May 8, 2021 | 04:04 AM
  #64
countyjag's Avatar
I very much doubt you will have any cause to regret this approach
Old May 8, 2021 | 08:57 AM
  #65
JezuzNoChill's Avatar
Originally Posted by countyjag
I think the point being made is not that the oil isnt performing as advertised, it is just that within 20 feet, the operating temperature has already reached the point where the "60" part is no longer necessary.
Well not quite the second number after the W or the 60 is the viscosity at operating temp or 100C. So that means that a 60 weight oil will be a bit thicker than 40 when the engine is warm. Or more precisely comparing Castrol 5w40 vs 10w60 the difference of kinematic viscosity at 100C is more than 60%
Sources:
https://www.ftfarfan.com/wp-content/...-40-US-TDS.pdf
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/85D76F35F027EAE080257F72003E3AF8/$File/BPXE-A84TF9.pdf
Old May 10, 2021 | 07:07 PM
  #66
NerijusHawk's Avatar
Thinking of trying out Mobil1 FS X1 5W50 on my 1995 X300 Sovereign 4.0 with 250 000 km. Anyone here used this oil?
Old May 10, 2021 | 07:49 PM
  #67
Vee's Avatar
Vee
I’m sure your engine would be fine with it.
Old May 11, 2021 | 12:40 AM
  #68
AnttiM's Avatar
Sources:
I am guessing (well not really guessing) that Xalty is pointing out that most of the wide range oils (eg 10-60) are loaded with viscosity index improvers (VII) or viscosity modifiers (VMs) that will lose some of their properties (vii´s tend to be polymers that shear in use iirc) at higher temps and then the "hot end" viscosity will drop to lower level. eg from 60 "weight" to 50 or 40 "weight"
Here is a link for deeper in the rabbit hole Viscosity Modifiers II @ Bob is the oil guy forum
Old May 11, 2021 | 04:01 PM
  #69
The viscosity holds up just fine.
https://www.m3post.com/forums/showthread.php?t=1504102
appel
May 24, 2018 09:56 AM
Jagisbest
Apr 19, 2017 03:08 AM
Malihide
Sep 29, 2015 03:21 PM
Kawi04636
General Tech Help
Feb 28, 2012 05:23 PM
