Engine Oil Leak? Oil Cooler Bypass O-ring Renewal with Pics
Old Feb 20, 2018 | 01:51 PM
Robman25's Avatar
Originally Posted by Scotlad
Robman25, the part you removed, was that on the 6cyl engine? Did that require a new gasket and is the filter now easier to access?
Yes it was the AJ6 I did make a paper gasket just to be sure to be sure.
Unfortunately I did not do the bolts up quite tight enough and loaned the car to my brother, it started to leak, I made a new gasket and tightened them up a bit more this time.
Old Feb 20, 2018 | 02:42 PM
Alster370's Avatar
There are two gaskets on the UK models, slightly different patterns, gives away which is which. I intended to replace both gaskets alongside the 4 o-rings when I did the job, however I couldn't get the block as it were, to separate into its two pieces, despite attempts with various prying tools, so I just replaced the gasket that sits against the engine block. Any tips? Although to be fair id probably just do the bypass delete as suggested If I tried again.
Old Feb 20, 2018 | 02:49 PM
Robman25's Avatar
Probably a BFH would have suggested it was a good idea to separate?
Old Mar 15, 2018 | 11:22 AM
Lumo's Avatar
So Lucky with all these good and useful information here about my leakage. Thank you Alhobro1 for your 'powerPoint' and all the others who reacted here. I drive a XJ Sovereign 3.2 L LHD 199, since 17 years. Now I understand what to do. I need four (4) O-rings (CAC5118) + two (2) gaskets. Is that correct ?
But in the manual (
https://www.jaguarclassicparts.com/uk/jaguar-xj-x300-parts/engine/sump-and-oil-delivery-systems/oil-filter-3-2-4-0-litre ) and on the CD-rom of the X300, You can't see/find these (different ?)gaskets. They are not mentioned, neither sketched.
Can someone help me to find these gaskets in the U.K. ? What are the number(s) of the parts ?
Does colleague ALSTER370 know where to find these in England ? Or another British colleague (I live in Belgium) ?
Perhaps at Jaguarclassicparts in Coventry ?
https://www.jaguarclassicparts.com/uk/jaguar-xj-x300-parts/engine/sump-and-oil-delivery-systems/oil-filter-3-2-4-0-litre But i need the parts Number again ...
Please help !
Luc
Old Mar 16, 2018 | 06:02 AM
Vee's Avatar
Vee
I bought Viton o-rings. I bought two sizes, 3x19 and 3x20. I bought the 20 because I believe someone used that size on this forum, but I also bought the 19 because it most closely matched the dimensions of the old o-rings on this thread.
Perhaps do a search for those sized o-rings?
Oh never mind, I see you’re trying to delete that bypass altogether...
Old Feb 14, 2021 | 10:14 AM
Stu Jags's Avatar
Old thread I know but Is the oil bypass horse shoe also a valve that opens to allow oil to pass if filter becomes blocked ? If this is the case then removing could be a problem one day ? I have removed mine but thinking just now but thinking ........
Old Feb 14, 2021 | 01:51 PM
xalty's Avatar
no the bypass is located in the filter itself. a lot of the later cars have no horseshoe at all.
4pot
Apr 25, 2025 06:04 PM
Pirk
Nov 25, 2020 10:43 PM
shemp
Sep 24, 2019 09:24 PM
Queen and Country
Mar 6, 2019 10:52 AM
NJ2003XJ8
Apr 27, 2016 09:08 AM
