GM 4L80E
Old Feb 16, 2021 | 11:12 AM
nickhand's Avatar
Default GM 4L80E
Can anyone confirm that the 4L80E used in the 95-97 XJR is the same transmission used in the later XJS V12's?
Old Feb 16, 2021 | 11:18 AM
xalty's Avatar
yes
Old Feb 16, 2021 | 11:50 AM
nickhand's Avatar
Thanks, I'm looking for a good used one. I've received one quote so far on a carry out rebuilt at right around 2000
Old Feb 16, 2021 | 07:58 PM
Jagboi64's Avatar
They do have different part numbers though, I'm not sure what the difference is. Perhaps the torque converter, as the V12 has a higher redline than the XJR.
Old Feb 17, 2021 | 05:58 AM
Robert Laughton's Avatar
I would imagine the bell housing would have a different shape?
Are the AJ16 and V12 bells the same?
The bells are not removeable.
Rob
Old Feb 17, 2021 | 06:24 AM
Doug's Avatar
As I recall the XJR/A16 used an adapter plate r to mate-up the 4L80E
Old Feb 17, 2021 | 09:51 AM
Jagboi64's Avatar
Correct, the XJR uses an adapter plate. The transmission is the 6.0 V12 volt pattern.
Old Feb 17, 2021 | 10:34 AM
nickhand's Avatar
I'll check that out. If I go used I'll at least buy a new torque converter anyway.
Gandalfthegray
34
Mar 22, 2024 10:02 AM
icsamerica
Sep 25, 2020 09:01 AM
AL NZ
Apr 4, 2020 08:38 AM
Jimmy James 905
May 1, 2019 03:11 PM
scarbro2011
Mar 27, 2016 04:41 AM
