Engine skips
Unless you have replaced it recently, I would add a crank position sensor to the list. Amazing how frequently it turns out to be the culprit on X300 faults despite rational thought suggesting otherwise!
thanks for that response
ok thanks
When was the last time the coils were replaced?
Cold engine would seem to discount most of the sensors failing, since most of them are not being read for fueling until the engine is warm and it goes into open loop.
My car had this. I removed each coil in turn and listened very carefully. Each of the cylinders caused the engine to run rough of course but I could also detect the occasional misfire on top of the rough running. When I disconnected cylinder 5 the misfire wasn’t there.
I replaced coil 5 and it was fixed!
