Engine skips
Old Feb 21, 2021 | 09:08 AM
D442's Avatar
Default Engine skips
My 1996 XJ6 vanden plas ,the engine skips sometimes more frequently . At worst it has a little hiccup every minute or so wether cold or warm.
Old Feb 21, 2021 | 12:00 PM
bjarnetv's Avatar
First thing is to remove the exhaust shield and check for cracks, next is coils and spark plugs - there might also be some oil-seepage in the plug wells causing shorts.
Old Feb 22, 2021 | 04:39 AM
countyjag's Avatar
Unless you have replaced it recently, I would add a crank position sensor to the list. Amazing how frequently it turns out to be the culprit on X300 faults despite rational thought suggesting otherwise!
Old Feb 22, 2021 | 01:31 PM
Vee's Avatar
Vee
Not sure I follow? What does a skip, or hiccup mean. A dip in the RPMs?
Old Feb 23, 2021 | 07:01 AM
D442's Avatar
maybe a single miss fire is a more descriptive term
Old Feb 23, 2021 | 07:02 AM
D442's Avatar
thanks for that response
Old Feb 23, 2021 | 07:05 AM
D442's Avatar
ok thanks
Old Feb 23, 2021 | 08:46 AM
Vee's Avatar
Vee
When was the last time the coils were replaced?
Cold engine would seem to discount most of the sensors failing, since most of them are not being read for fueling until the engine is warm and it goes into open loop.
Old Feb 24, 2021 | 04:51 AM
Scaphan's Avatar
My car had this. I removed each coil in turn and listened very carefully. Each of the cylinders caused the engine to run rough of course but I could also detect the occasional misfire on top of the rough running. When I disconnected cylinder 5 the misfire wasn’t there.
I replaced coil 5 and it was fixed!
Old Feb 25, 2021 | 04:20 PM
Vee's Avatar
Vee
Or you can just order a set of six QYL branded coils, which forum members here have had very good experiences with, and swap them all out!
Jakob Farewell
Jun 22, 2015 03:55 PM
w1n9m4n
Apr 23, 2015 10:19 AM
holybananas
Photography
Jan 29, 2012 07:48 AM
