Err and not the Air Flow
Old Nov 5, 2022 | 05:20 PM
cdma's Avatar
Default Err and not the Air Flow
Today I swapped out my manifolds for ceramic-coated manifolds and replaced all the O2 sensors. I only ran into one issue where the metal lines that go into the manifold, one connector got stripped out. I was able to get the problem temp fixed until I get another one. So everything went well...so I thought. After replacing it, I figured I would go burn out all the excess coating, started the car and I received the "Err" on my climate control. So I figure maybe the cabin air flow sensor went bad. Replaced it and the same thing. What causes this other than the cabin airflow? I did have the bumper removed to get painted but when I picked it up I did not get that error unless something got loose on the way home. Any ideas?
By the way no other fault codes
Old Nov 5, 2022 | 06:24 PM
cdma's Avatar
After doing a little research it appears to be my outside air sensor. Must have come loose because I went to check the outdoor temp and I got - - F. Anyone know where it is?
Old Nov 5, 2022 | 06:37 PM
Parker 7's Avatar
The outside air sensor for the climate control is in the left front wheel brake cooling duct by the bumper fittings
Old Nov 6, 2022 | 07:15 AM
cdma's Avatar
Got under the car and the sensor was unplugged so I plugged it in. Started the car and still have the Er. I am getting the outside temp now so for sure that is working. Any other ideas?
Old Nov 6, 2022 | 10:01 AM
Parker 7's Avatar
I'm sure you've done this test
Old Nov 7, 2022 | 08:35 AM
cdma's Avatar
Problem resolved. Although I had reattached my outside sensor, I did not take it for a drive and let it calibrate. All good now
lear60man
Jan 22, 2022 09:57 AM
osyris
Jan 15, 2022 10:21 AM
fmertz
Jan 28, 2017 07:08 AM
whyhellothere
Aug 26, 2015 06:47 PM
Beartoy
Aug 11, 2014 08:45 AM
