Escaping Gas fumes/pressure
Old 05-26-2010, 12:43 PM
Brianvabeach's Avatar
Question Escaping Gas fumes/pressure
95 XJ6 Left hand Drive:
Recently when I remove fuel cap to refuel I have a lot of pressure inside tank and it blasts you in the face when you take off cap. Dont have a problem refueling, but pressure just builds in tank. Could this just be a bad/faulty gas cap????
Old 05-26-2010, 01:51 PM
Fraser Mitchell's Avatar
Received 2,435 Likes on 1,941 Posts
It could be, but on the other hand, I have had other cars, (not Jaguars), with the same symptom and had no bother at all. If you have it the first time on a new car, (new to you), you tend to accept it as a feature, not a bug.
I have to say my XJ6 doesn't do it, nor did my previous Rover 75
Old 05-27-2010, 05:59 AM
I have had the car fro 3 years, and this just started. The car does sit alot, only gets driven maybe 1 to 2 times a week. I believe the gas cap has a pressure release system in it right?
Old 05-27-2010, 12:49 PM
Markus's Avatar
There is an "Evaporative Emission Control Canister which may have become plugged or have a kinked/plugged hose. The gas cap is NOT at fault when you have this issue.
Details readily available at alldatadiy.com (no affiliation, etc)
aode06
07-28-2023 02:26 PM
hkmcmast
11-29-2015 06:56 AM
workworkwork
10-23-2015 10:26 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
10-05-2015 04:05 PM
Quick Reply: Escaping Gas fumes/pressure
