Finding the Spark Plugs??
Old Nov 12, 2007 | 08:47 PM
dougs02's Avatar
Default RE: Finding the Spark Plugs??
It's the cover right on top of the engine. It has three torx screws holding it down. There is a coil on top of every spark plug. these are held in place with two screws (bolts) each. Each one of these coils have a gasket that is probably pretty rotten and unusable a second time. I made new ones with gasket material and coated them on both sides with silicone sealer and let dry. I don't know if auto parts stores stock them or not. I'm sure the dealers do.
The coils have a rubber boot that attaches to the spark plug. You should loosen each plug a few turns and blow out the recess with compressed air to get rid of any grit or other material there and then remove the plugs.
Old Nov 13, 2007 | 09:09 AM
dougs02's Avatar
Those coils are ignition coils. No they don't have to be replaced during a normal tuneup. I have never had one fail, but i believe other owners have.
Instead of one coil supplying spark to all of the plugs, a lot of newer vehicles With computer controlled engines have an ignition coil for every spark plug.
Doug
dsnyder586
Dec 29, 2024 07:39 PM
cissdm
May 3, 2016 06:02 AM
Bones
Sep 8, 2015 08:34 PM
MrMellor
Sep 7, 2015 10:22 AM
Bowman
Sep 3, 2015 03:17 PM
