Front Crank seal distance piece
Old Oct 17, 2022 | 08:37 PM
Spud Maat's Avatar
Default Front Crank seal distance piece
So i am looking at what appears to be a front crankseal leak.
so i have ordered a front crankseal no problem.
but found that there is a seal runner that sits over the crank.
basically a metal ring
EAC2464 Distance Piece
apparently this ring wears and after 360000km is probably overdue for a change.
the issue is that this part is NLA and i can’t seem to get my hands on one anywhere.
if i don’t change it i hear the leak will likely just happen again,
no i have heard it can be turned around possibly,
other options is take it off, send it off to a machine shop and get it remade or resurfaced.
anyone got any luck finding one of these?
Old Oct 18, 2022 | 12:45 AM
watto700's Avatar
G'day Spud,
If you can't track down the distance piece you might be able to try this,
https://www.timken.com/products/timk.../redi-sleeves/
Cheers,
Jeff.
Old Oct 18, 2022 | 01:01 AM
Spud Maat's Avatar
Possibly an option.
i just find it really strange that jag make the crank seal and distance piece as seperate components and then also that nobody makes the distance piece as really it is needed when changing the seal.
illogical if you ask me
Old Oct 18, 2022 | 06:17 PM
watto700's Avatar
G'day Spud,
You could also try this mob, I got a seal and distance piece from them a while ago.
If they dont have the part listed give them a call as they sometimes stock items which are not listed on their website.
Cheers,
Jeff.
https://www.ebay.com.au/itm/New-Jagu...75.c1#viTabs_0
Old Oct 18, 2022 | 06:22 PM
Spud Maat's Avatar
Originally Posted by watto700
G'day Spud,
Cheers,
Jeff.
yeah i use these guys often.
i got the seal from them.
and i told someone the other day exactly that.
call them and ask.
but yeah when i called them the other day and asked the don’t have.
Old Oct 19, 2022 | 08:23 AM
Larry Louton's Avatar
Hello Spud, Easy solution, Clean the distance piece, Then put it in reversed so the seal rides on a new area.
Thank you.
Larry Louton
Old Oct 24, 2022 | 07:58 AM
aholbro1's Avatar
Ignorance is bliss, I guess. I changed the front crank seal on my 95 several years ago when the damper was out for rebuild. Neither saw nor knew about any distance piece. Hasn't leaked. Car has 270k on it now, can't recall how many miles when I changed the damper/crank seal, but it is documented in here somewhere, but in any case, I'm sure it was at least 100k miles ago.
OnFire
Feb 18, 2022 11:53 AM
giandanielxk8
Jan 5, 2022 03:42 PM
bocagq45
Oct 29, 2014 04:41 PM
krswen
E type ( XK-E )
Jan 3, 2014 02:16 PM
magnoliav12
Feb 22, 2013 06:06 PM
