front hub interchange
Old Mar 11, 2025 | 03:44 PM
danz503's Avatar
Default front hub interchange
i need front hubs for a 96 xj6. the part number on my damaged ones are cbc-5209. does anyone know what will interchange with these? i'm thinking maybe even a ford hub or? any help will be appreciated.
Old Mar 11, 2025 | 04:13 PM
Parker 7's Avatar
The later about the same chassis / suspension X308 or V8 ( more Fordized ) has a different bearing setup besides other unknown things
Motorcarman ( Bob ) would be your man and his great value in his experience
This for the X308 :
Xj 1998 - 2003 (from 812317 To F59525) (x308) Classic / Hub And Vertical Link | Jaguar Land Rover Classic Parts
Old Mar 11, 2025 | 04:15 PM
944play's Avatar
I think the part you're looking for is CAC9834. Welsh had used ones in stock when I asked in September. $215 might make you want to look on the 'Bay, though.
Old Mar 11, 2025 | 09:30 PM
Doug's Avatar
Also used on XJ40s. Finding good used ones shouldn't be too difficult
Old Mar 11, 2025 | 10:04 PM
danz503's Avatar
Default 96 xj6 front hubs
This for the X308 :
thanks for the quick reply. the hubs on my front suspension are very similar to ford hubs. timkens at both ends, inboard and outboard. thats why i was thinking ford hub may be easier to find and cheaper. is bob someone on this site?
Old Mar 11, 2025 | 10:07 PM
danz503's Avatar
Old Mar 11, 2025 | 10:11 PM
danz503's Avatar
thanks for the reply. .i was hoping someone knew if ford hubs would interchange. they look like a ford hub in that they have timkens on both ends of the spindle. might be wishful thinking on my part.
Old Mar 12, 2025 | 09:52 PM
944play's Avatar
I suggest renewing the threadlocker on the splash shield bolts while you have the hub off. Both of my front brake shields suffered from backed-out screws, a couple years apart.
Old Mar 13, 2025 | 01:02 AM
danz503's Avatar
thanks, i will be sure to look at that.
Old Mar 13, 2025 | 04:24 PM
Parker 7's Avatar
Bob may come along after catching up as he was a Jaguar Doctor at a Jaguar dealership during X300 and X308 years at least maybe earlier close X40 ( square body 4 door )
Benkitties
XJ40 ( XJ81 )
Aug 28, 2022 03:57 PM
Stuart Satter
Apr 20, 2021 11:31 AM
laguillotine
Mar 7, 2020 09:45 AM
randyb
Jul 15, 2013 04:19 PM
