Front shock bush swap - how tight?
Old Nov 15, 2013 | 09:49 AM
Ziggy's Avatar
Default Front shock bush swap - how tight?
Just swapped my front upper shock mount bushes - the old ones were properly ruined!
Relatively simple question I hope: how tight should I do the nut back up?? Just enough to put a bit of pre-load on the bushes?
Thanks in advance!
Old Nov 15, 2013 | 11:05 AM
Doug's Avatar
Since nobody else has replied yet....
I tighten 'em until I see a small amount of squish...and then add 1/2 turn.
That's my rule-of-thumb method. I've never replaced 'em on my X300 so if anything unique is required I'm not aware of it
Let's wait for others to chime in
Old Nov 16, 2013 | 09:04 AM
Ziggy's Avatar
Ta Doug; that's pretty much what I've done so far. The service manual just says 'refit in the reverse order to removal' - not very useful!
Old Nov 16, 2013 | 12:01 PM
JTsmks's Avatar
I used stock style "foam" bushes recently (on my XJ6L and XJS) and took the nuts down as far as I took them off which was where the Jaguar factory put them ie. install in reverse of removal, now that being said if you suspect some one was there before then your on the "squish" method, plus some replace their "foam" ones with "rubber" style ones. Just for grins I took the "foam" ones down till they started to "squish" and there was still a lot of play with my hand so I took them down to where I pulled them off which left me no ability to easliy move the shock in the mount. Rubber ones do not need as much "squish" as the foam ones IMHO.
Old Nov 16, 2013 | 03:56 PM
Ziggy's Avatar
That would be a LOT of squish! Someone's been in there... thanks though.
Old Nov 16, 2013 | 04:29 PM
AllanG's Avatar
Not sure if it helps at all but the VSM says tighten the top nut to 15.5 - 20.5 Nm.
Old Nov 18, 2013 | 04:40 AM
Ziggy's Avatar
That does help some - I'd never get em squished down as far as the old ones were with that little force!
H20boy
Dec 24, 2024 03:23 PM
Neil1664
Jan 20, 2022 08:59 PM
KarimPA
Sep 12, 2015 08:15 AM
EZDriver
Sep 8, 2015 09:25 AM
Tar
Sep 6, 2015 11:24 AM
