Front shocks and springs
Old Dec 20, 2023 | 06:40 AM
Spud Maat's Avatar
Default Front shocks and springs
Hi,
Looking to likely to replace/upgrade my front shocks and springs in the near future.
question is.
what is the best wat to go?
I have seen a lot of mention for bilsteins as far as shocks go, but no mention as far as springs go.
supplier and part numbers would be great. esp here in AUS
from what i can tell part numbers are the same as xj40? are they also same as x308?
what I do notice is it seems there is a slight sag in the ride height of my cat and I get a slight rubbing on the front right which I do not get on the front left.
i suppose also it would be worth checking/replacing upper/lower control arms & tie rods.
what is the best course of action for all the suspension bushes and rubbers?
i have heard urethane can be too harsh on ride comfort?
once again suppliers and part numbers would be great.
Old Dec 20, 2023 | 07:08 AM
Doug's Avatar
Originally Posted by Spud Maat
Hi,
question is.
Bilsteins were factory fit, with Jaguar using several variations. Some might still be available thru Jaguar.
Via the non-factory pipelines it appears the Bilstein offerings come down to just two choices, the softer B4 series and the firmer B6 series.
The is a large amount of interchangeability with X308 and XJ40 shocks, if you eliminate to self-leveling and automatic adjusting types often used on those cars
If your springs are badly sagging, or broken, then you don't have much choice but to replace them.
On the older older model Jags spring replacement is often very problematic. Many owners avoid replacing them when possible. Very often the replacement springs yield incorrect ride height. Not sure if you're likely to encounter the same problem with X300 replacement springs. Others will chime in.
Old Dec 20, 2023 | 09:09 AM
Parker 7's Avatar
Springs where recently replaced be someone on this forum
Power Flex brand bushings
They come in different densities for hard or soft range , they denote by color
Use the shore A unit of measure
Jaguar XJ6, XJ6R - X300 - X306 (1994-1997) Replacement Suspension Bushings (powerflexusa.com)
You can actually mold your own
Old Dec 20, 2023 | 10:17 AM
Parker 7's Avatar
This from a Bilstein catalogue
First 24 number is the front shocks as different than rear ( I would have to pull up full catalogue to double check )
For your comfort ride you will be using the B4s
Shocks - Jaguar Forums - Jaguar Enthusiasts Forum
Old Dec 20, 2023 | 04:57 PM
SC Chinchilla's Avatar
I just got H&R lowering springs but they seem like stock equivalents for XJR6. At least up front, never tested the rears. I got mine here from urotuning.com. But do be aware they're probably a special order, mine were significantly delayed but did actually arrive. I thought they'd just cancel the order but hey, they actually shipped out!
https://www.urotuning.com/products/h...12961265483831
Old Dec 20, 2023 | 11:28 PM
Parker 7's Avatar
By lowering springs was that your objective to be lower than factory bumper height ?
H&R Lowering Springs - Jaguar Forums - Jaguar Enthusiasts Forum
Note that yours was the supercharged version and maybe different spring part #
Old Dec 21, 2023 | 12:15 AM
Spud Maat's Avatar
anyone know the exact diff between AA and AC?
these two, both from the same supplier, i would be looking to get the bilsteins without knowing more
https://www.ebay.com.au/itm/19262135...Bk9SR9jXirCRYw
https://www.ebay.com.au/itm/20195942...Bk9SR9rXirCRYw
also,
anyone know about SACHS quality?
Old Dec 21, 2023 | 12:36 AM
Spud Maat's Avatar
yeah i saw that kit online from simpleperformancejaguar on ebay.
but at AU$1600 + AU$800 shipping, i don't think so.... unless there was no better option.
https://www.ebay.com.au/itm/224398208312
although, i might be looking at AU$1500 all round for shocks from local suppliers anyway......
and then still need springs......
Old Dec 21, 2023 | 03:31 AM
Spud Maat's Avatar
Or……
maybe i wait….
save some cash….
and install airbags…..
Old Dec 21, 2023 | 04:19 AM
countyjag's Avatar
Replacing the front springs safely really requires the special spring compressor tool. There are videos showing a method using screwed rod, but the tension involved is of biblical proportions, and it is not for the feint hearted. Expect a struggle with some of the spring pan bolts too, so have a few new ones to hand.
when I eventually got mine off, I discovered a break at the very end of one spring which was obscured by the spring pan in situ, but probably accounted for the slight lopsidedness. The new springs ( different rating for my XJR) restored the original from factory stance, which makes the car look very purposeful, so a job worth doing.
Old Dec 21, 2023 | 07:24 AM
Parker 7's Avatar
Countyjag's point on the compression tool is very important.
Here in the states the auto parts stores have tool loan program for free
I did that on springs for a different car
Old Dec 21, 2023 | 07:12 PM
Yeah, to clarify, I wanted to go lower than an XJR6, and the H&R springs I got where about equivalent to the stock XJR6, which is lower than "plain" XJ6.
If you do use the threaded rod method make sure to get good grade 8 or grade 10.9 kit. I found that often the spring plate would bind up in some spots or be loose in others, often putting the force on mostly one nut. There's a good 5-6 inches of preload on each front spring, too, so it takes forever.
Old Dec 21, 2023 | 07:28 PM
Spud Maat's Avatar
would most certainly not touch springs without a compressor
Old Dec 21, 2023 | 08:14 PM
watto700's Avatar
G'day Spud,
I have had the front springs off and back on several of the Jags I have owned without any problems at all.
Have a look at the attachment to see what I used.
Cheers,
Jeff.
File Type: docx
Old Dec 21, 2023 | 08:50 PM
Doug's Avatar
also,
MNA2140AC = XJR
I don't see an MNA2140AA in the Jaguar catalog. Sometimes the numbers change.
MMD2140AC is 4.0 comfort suspension
From years ago I recall Jaguar showing more listings. For example, different numbers for German, North American, and ROW XJR/6s. They've consolidated the listings ow.
Sachs are good quality although I'm not aware of them being performance - oriented
Old Dec 22, 2023 | 01:35 AM
Spud Maat's Avatar
mmm... interesting thought....
https://ceika-store.com/en-au/produc...6-03?locale=en
petemohr
Oct 11, 2019 03:31 PM
Greg in Tampa
Aug 16, 2019 06:05 AM
m5f4k8
Jun 10, 2017 06:20 AM
Dave1109971
Oct 19, 2015 03:05 AM
