Fuel pump relay bypass with jumper wire
Old Apr 9, 2013 | 08:45 AM
metal144's Avatar
Default Fuel pump relay bypass with jumper wire
I would like to do a quick fuel pump test and wanted to know if removing the fuel pump relay and putting a jumper wire between pins 85 and 87 will the pump run without any damage to the ecm.
Old Apr 9, 2013 | 04:20 PM
plums's Avatar
if those are the power poles of the relay, no problem.
i jump from battery +ve to the pole leading to the fuel pump.
Old Apr 10, 2013 | 07:32 AM
motorcarman's Avatar
The terminals you need to 'jump' are 30/87.
85/86 are the relay 'coil' terminals.
bob gauff
Old Apr 10, 2013 | 08:05 AM
Brutal's Avatar
yes Bob is correct. 30/87 are the terminals to bypass just about any of that style relay. Do the ones you said and youll smoke the driver in the ecu depending on wether its a pos or neg trigger
Old Apr 10, 2013 | 08:13 AM
plums's Avatar
That's why I weaseled on the pole numbers.
Old Apr 10, 2013 | 09:43 AM
steveinfrance's Avatar
Don't the ECM drivers even have over current protection? Scandalous if they don't.
Old Apr 10, 2013 | 03:58 PM
Brutal's Avatar
Originally Posted by steveinfrance
don't the ecm drivers even have over current protection? Scandalous if they don't.
yes, its called a relay. This is why you dont go checking circuits with test lights but use a dvom. Test lights just to turn on the light can blow a driver. Most circuits now days are neg triggers from the ecu with power on the other leg. If you dont know what youre checking, you can really fubar something easily
Old Apr 11, 2013 | 02:14 AM
Brutal -a relay with a s/c coil is a source of high current not protection against it.
The function of the relay is to switch loads too big for the on-board drivers.
It costs nothing to incorporate current limiting into an IC and if it hasn't been done the designers should be taken outside and shot.
Old Apr 12, 2013 | 09:42 AM
Brutal's Avatar
thanks Steve, Im well aware of what a relay does, how it functions and its purpose. I realise you sometimes miss my tongue in cheek sarcasm
Old Apr 12, 2013 | 10:05 AM
I promise not to have you taken outside then - we couldn't manage without you.
I thought you might need a little tutorial on relays.........................
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
ccfulton
Sep 20, 2015 05:15 PM
1964Daimler
Sep 9, 2015 11:28 AM
Sprayall
Sep 3, 2015 07:49 PM
