garage door feature.....
Old May 19, 2012 | 08:26 PM
1badcat's Avatar
Default garage door feature.....
So on my 97 XJR it has 4 diffrent buttons to control 4 diffrent garage door openers. So how do i program for 2 of mine?
Old May 19, 2012 | 09:13 PM
aholbro1's Avatar
If your openers are rolling code, don't bother.
Seem to recall it was '98 that Homelink switched up to rolling-code-capable. Still, if they are "old" garage door openers, it may work for you. Try a search on "Homelink" to find the procedure if you don't have the owner's manual. It is a push-n-hold combo of buttons - I suspect you can find it on the homelink site.
Old May 19, 2012 | 09:28 PM
Doug's Avatar
In the "Quick Link" thread at the top of the X300 section you can download the owner's manual which should have the programming directions but, as mentioned, it won't work with rolling code technology
Old May 19, 2012 | 09:51 PM
motorcarman's Avatar
Here is some old info for the old systems.
bob gauff
File Type: pdf
Old May 19, 2012 | 10:24 PM
mgb4tim's Avatar
I really hope mine work when I finally get my car home. If not, I'll be fabricating a new overhead console. I'll use a Cadillac homelink module - cheap, easy to mold, and works with rolling codes. Ialso want to add a small lcd panel, 2.5" for a reverse camera-also spoiled by my Prius on that one.
Old May 20, 2012 | 09:38 PM
1badcat's Avatar
sweet thanks man!
99xk8guy
Sep 29, 2025 10:51 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
DuhCar
Sep 11, 2015 10:58 AM
